Sponsored by: CARiD
What is THIS!
Old Dec 23, 2006 | 03:19 PM
mattreeve's Avatar
What is THIS!
I have this thing on my oil pan anyone know what its for?
It not in my maunual can anyone help me out?
Old Dec 23, 2006 | 03:24 PM
mattreeve's Avatar
its not the oil level sender its tho other one i cant seem to figure out how to post pics.. the one with one wire
Old Dec 23, 2006 | 04:18 PM
7dust's Avatar
Irregular Here
cooter valve
Old Dec 23, 2006 | 05:55 PM
mattreeve's Avatar
wtf is cooter valve i run a 12a
Old Dec 23, 2006 | 06:27 PM
old_skool's Avatar
you know you want this
the cooter valve regulates the flow of oil to the cooter proportioning block, which distributes oil to the upper and lower halfs of the intake area. get rid of it, and you car will have more testosterone.
Old Dec 23, 2006 | 07:54 PM
mattreeve's Avatar
So what is its purpose will it make my engine blow? or does it serve no purpose?
Old Dec 23, 2006 | 08:22 PM
mattreeve's Avatar
bump please let me know if i can run without this on?
Old Dec 23, 2006 | 08:36 PM
rgordon1979's Avatar
LS what?
Mazda put it there for a reason. Leave it alone.
Old Dec 24, 2006 | 10:19 AM
rustnrot's Avatar
That is an oil level sensor. It is a float switch. Very few cars have them, I know of no others that do. Turns the oil light on when low oil level. Not the same as an oil pressure switch, which also turns the light on when the oil pressure is low (cannot remember right now if they are the same or different lights). Anyway, it is there since the car is designed to burn crankcase oil. You can remove it, if, like most enthusiants, check your level oil regularly.
Old Dec 24, 2006 | 11:30 AM
diabolical1's Avatar
if i'm not mistaken, there are 2 "things" you can see on the oil pan besides the plug. one is the level sensor (held on by 3 bolts), the other is the temp sensor (looks like a larger verison of the water temp sensor). which are you referring to?
Old Dec 24, 2006 | 12:03 PM
peejay's Avatar
Old [Sch|F]ool
If it's only one wire, then it is the oil temp switch.
It's not a temp sender, it's the switch that engages the sub-zero assist.
Old Dec 24, 2006 | 12:05 PM
peejay's Avatar
Old [Sch|F]ool
Not familiar with the FD, but no 1st-gen or 2nd-gen ever had an oil pressure idiot light.
Heck, the SA didn't even have an oil pressure gauge. They only had the low oil level light. That shows you how much Mazda is concerned with oil pressure.
Old Dec 24, 2006 | 12:50 PM
mattreeve's Avatar
lol I removed the sub zero assist and the charcoal canister so i guess this things useless?
