Quick offset question.
Old Dec 7, 2006 | 12:16 PM
PrjctRxSe7en's Avatar
Question Quick offset question.
being in iraq and limited resources, and limited time to actually look it up... i was wondering im on the process of purchasing some rims and tires for my 94 rx7... i have eibach springs, im looking for 18X9 for front and 18X10 for rear, with 265/40/18 for rear and 255/40/18 tires for front, what should my offselt be for my rims??? thanks alot again...
Old Dec 7, 2006 | 12:22 PM
Mahjik's Avatar
Mr. Links
I had rubbing issues with a 255 in the front on a 9" rim at +43. If you go with a 245 tire, you can probably get away without rolling your fenders and somewhere around a +45.
Old Dec 7, 2006 | 12:32 PM
so your saying go 245 in the front?? what about the rear, is 265 ok or is that too big? and thats +45 both front and rear?
Old Dec 7, 2006 | 12:37 PM
Mahjik's Avatar
Mr. Links
With the rear, you can go more aggressive if you like. It seems that you want to run a staggered setup so you won't be worrying about rotating your tires all around.
You could probably go with something in the lower 40's for the rear to give the car a more balanced look. 265's would be fine. With a 10" rim on the rear, a lot of people will probably suggest a 275. IMO, I wouldn't split the front to the rear more than 2 sizes (i.e. 245 F and a 265 R or a 255 F and a 275 R).
For a reference, the stock rims at 16x8 are a +50.
Old Dec 7, 2006 | 12:58 PM
ok so im going to go with 18X9 R and 18X8 F and 265/35/18 R and 245/35/18 F and i should be good?? with a offset of +45 for both f and r??
Old Dec 7, 2006 | 12:59 PM
ptrhahn's Avatar
You'll want 35-series tires for 18" above a 235mm width.
Here are the combos you could do, width wise:
245/F, 265/R
255/35 F, 265/35 R
255/35 F, 275/35 R
The fronts will probably require a fender roll, the rears should be fine.
Old Dec 7, 2006 | 01:01 PM
ptrhahn's Avatar
Those are a little large for the rim, particularly the 245 on 8" front. Any way you can get decent offsets in at least 8.5 and 9.5" rim widths? (you could use 9's and 10's in those widths)
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
