13B 6 port operation ideas with free flowing exhaust
Old Mar 8, 2002 | 12:31 PM
jbontke's Avatar
Damn security clearances
Well most of you know that when you install a free flowing exhaust on a 13B 6 port the other 2 ports don't open with out back pressure. Does anyone know how much back pressure it takes to open them? And do they open all at once or gradually? And at what RPM the begin to open and what RPM they are fully open?
Reason for asking is that I have seen some people use the air pump to open the other 2 ports. Can some one explain how they did this?
I was going to setup up a system that was servo actuated and the servo would be controlled by a MSD rpm activated switch that would allow you to dial in the RPM that it would open the ports. I know that when you change an engines peak HP area by altering the exhaust flow, you also change the points that the engine begins to make power. So by adjusting the ports RPM activation you could keep the torque up on the low end and have the ports open at the best RPM for the free flowing exhaust.
Another idea was to have them work off vaccum, much mile the vaccumm secondaries on a carb. As the engine load increased the vaccum secondary diaphram would slowly open the ports corresponding to engine load and give you a smooth port opening and not slam it open (causing a momentary lean condition in the engine) like the MSD operation would. I guess there is a spot on the 2 other ports that you could connect an arm to the diaphram and make it work. Also most vaccum secondary diaphrams are adjustable allowing the rate and RPM at which tey open to be adjusted.
Anyone tried this??
Old Mar 8, 2002 | 02:29 PM
speckamp's Avatar
8krpm is not enough
Well, the aux ports work by positive pressure, not vac, so that won't work. I'd do a quickie search around some second gen sites, cuz I swear I saw a mod like this on one of the "second gen tech" sections of a site. Bascically you rig your airpump to open the aux ports via a solenoid and a rpm switch like you talked about.
The other alternative is to just take them out, and put block off plates over the actuator mounts. Sure, you'll lose a touch of low end, but you'll gain a little more top end (unless you're running pinapple racing 6p sleeves, then I'd suggest keeping them (or selling them to me))
--matt
Old Mar 8, 2002 | 02:44 PM
Directfreak's Avatar
I am a Jeeper Now.
My original Idea was to have open up with Boost pressure from the Turbo Setup I was going to build.
Originally I was going to do a custom 6-port Turbo setup with actuactors opened up by boost.
I was going to place a small in-line solenoid so it would
open up slowly, and also not to push too much pressure to the actuators.
I believe they open at only 3lbs of pressure, and at approximately 3700 RPM. But I could REALLY be off, since I haven't seen my Haynes Manual in weeks.
Either way, when I opened up my "organ donor" engine, it was toasted inside, all the bearings where shot, and the housings where porrted too large for Turbo operations. (I'll post pics soon)
So That's why I am just going to get a J-Spec TII.
According to Crispeed, I should be able to make about 400-425 rwhp on a stock block, without even porting.
Also, those engines have significantly less miles that US-Spec versions.
So that will be my new route.
Sorry...
When it comes to Turbo First Gen's..
my mind wanders...
Old Mar 8, 2002 | 02:54 PM
yayarx7's Avatar
Are you Nucking Futs?
A stock port T2 with 400-425 hp? Is this with aftermarket Fuel system? Do you have to dowl the block to get that kind of boost? What turbo? I never heard of such a high power level on a stock port. Fill me in on your intended setup.
Old Mar 8, 2002 | 04:01 PM
WackyRotary's Avatar
standard combustion
Its rather simple to convert your port actuation to be off the air pump along on a '84-8813b 6port engine. This way the exhuast doesn't need to be at all restrictive. Their are many sites out there. Do a search on "6port actuation. The main things you need is a valve, and some heater hose and a conection of from the air pump to a adjustable valve. Somewhere in the line put a tiny hose that goes to the actuators. Then adjust the valve to allow the ports to open at 3600-4000rpm. Very easy, costs about 15bucks. Downside, your using the airpump, but sure its not draggin more then 1-2hp@8000rpm.
Old Mar 8, 2002 | 04:15 PM
I am a Jeeper Now.
Stock Port (91) J-Spec Engine (yes, dowl pinned)
Haltech E-6K
3rd Gen Intake Manifilold
Stock Primary Injectors
1600 cc Secondaries
Isuzu NPR Intercooler
Turbo Header (Divided Design by SFP, not stock manifold)
Turbo 60-1 compressor housing machined for a T-70(70mm) compressor wheel and on the turbine side a P-trim with a 1.0 divided housing
HKS wastegate
At about 15 lbs of boost.
TII Tranny
Dunno about the Rear end yet..
Note: I will NOT Run that much boost on the street, that will be strictly for 1/4 mile track times.
After all that..Mariah Widebody.
I will post detailed info online as I build it over the next few months. By the way my builder is Crispeed.
Old Mar 8, 2002 | 07:02 PM
Max7's Avatar
Admitted Sevenaholic
Just remove the actuators and sleeves and install Pinapple Racing Sleeves, you'll never miss the little bit of low end loss
and never worry again, "Are my 6 ports opening?"
Old Mar 8, 2002 | 10:04 PM
I am a Jeeper Now.
I thought the Pinapple Racing Sleeves are direct replacements for the stock ones (actually, they are modified stock ones).
I believe they open and close normally with the stock actuators, unless the owner deliberately removed the actuators or wired them open.
Pineapple Racing Sleeves
Old Mar 8, 2002 | 10:23 PM
Max7's Avatar
you can use them as stock replacments, or remove the center rod and locktite them in place
Old Mar 8, 2002 | 10:45 PM
REVHED's Avatar
Hunting Skylines
Haltech E-6K
1600 cc Secondaries
HKS wastegate
TII Tranny
If you're gonna pull the engine down for dowelling why wouldn't you port it at the same time. Doesn't make sense. Especially if you're aiming for those sort of power figures.
Old Mar 8, 2002 | 11:40 PM
I am a Jeeper Now.
I will look into it. I am was planning to use the stock block without opening it up. When it blows up (eventually) then I was going to port the **** out of it.
I will speak to my builder and have him decide.
I know you put more than 450hp out, doweling is really recommended. But remember, I don't plan to run that much boost regularly.
For street driving, the boost will be at about 11-12lbs, and HP will "only" be in the 350 range. Its gonna be hard not to kill myself with anything over 250hp on a first gen.
Old Mar 9, 2002 | 01:41 AM
yayarx7's Avatar
I still cannot see that kind of power with a stock port, even with those mods. but i am no expert and your engine builder should be so I digress.
But if you get 400 with those mods, a simple street port would probably boot you over 500, don't ya think?
Old Mar 9, 2002 | 02:01 AM
I am a Jeeper Now.
Engine Builder = Crispeed
His drag car is running 9.20's in the 1/4 and has *classified* horsepower. And that's un-tubbed with No traction.
I Hope so, but honestly I don't know. I am going by what he's told me can be done out of a stock 91'13BT.
I know you can get even more out of the 3rd Gen engines (Bigger stock Ports)
I know that he claimed that you CAN get that kind of horsepower of the stock port.
However, it may not necessarily be the setup that he is planning for me. I want a street car, so I don't need to run a HUGE Boosting/Slow Lagging unit in it either.
If the HP is not there, it will be damn close, he has a Dynojet in house to know for sure. Again, as the project continues, I will provide more details and post.
I am specifically going for a J-spec so I don't have to open up a good low-milage engine. Otherwise I'd just get a local 13BT, rebuild and port it.
Old Mar 9, 2002 | 02:55 AM
peejay's Avatar
Old [Sch|F]ool
what's so classified? 650whp at high boost/no spray, 692whp at lower boost/with spray. Of course, that's with a half-bridge engine, not a stock port
Old Mar 16, 2002 | 08:59 AM
I think the 3PSI is right, but the rpm depends on the engine load. Make another hole in the pre-cat or somewhere closer to the header...... move it up until you feel the other ports open. Or do it the hard way and put some pressure gauges on there so you can remotely monitor pressure in the pipe, see what happens.
Old Mar 17, 2002 | 08:56 PM
itzweapon's Avatar
the 6 ports.. with headders.. are useless... you will never notice the diffrence if they are removed.
Old Mar 17, 2002 | 10:25 PM
jbontke's Avatar
Can you elaborate? Are you saying when you add a header the 6 ports are usless(not reffering to the functionality of the other port opening)?
Old Mar 17, 2002 | 10:44 PM
I am a Jeeper Now.
That's incorrect. There are Special Headers/Exhaust systems for the 6 port engines.
They are designed with a small flange to still provide backpressure to actuate the 6 ports.
Check Racing Beat, Mazdatrix, or Mindtrain.
YOU WILL FEE THE DIFFERENCE..
Old Mar 18, 2002 | 11:52 AM
itzweapon's Avatar
I've never felt any diffrence by removing the 6 port acuators but then again I've not had a stock or normal aspirated Rotary in Many years.
I do know if the little tube that routes gases back to the 6 ports.. but we usally remove it and block the hole up.
Old Mar 18, 2002 | 12:04 PM
standard combustion
Does Pineapple racing fill part of the sleeves with a devcon or wield in it to conture it to get the extra flow characteristics with out the adrupt edges? How much do they charge for a set?
I don't see why anyone would wire them open when its fricken easy to just operate them with the air pump and a 5dollar adjustable valve from a manards? ..and its very, very reiable I had mine this way since I installed headers and intake and removed cat.
Old Mar 23, 2002 | 03:04 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Here's the info...
http://www.pineappleracing.com/Prod-pr6pi.html
Old Mar 23, 2002 | 06:21 PM
yayarx7's Avatar
FYI the actuators are supposed to start to open at 1.8psi and finish opening at 2.7psi per the FSM
Old Mar 23, 2002 | 10:07 PM
Montrealer's Avatar
What I plan to do for this, considering i have no cats,
I can the hose that goes out to the cat, but keep the rubber fitting. to the rubber hose, I attach a "T" where one end goes to a pluming valve and the other goes to the six port actuators, by opening and closing the valve, I sould be able to ajust the rpm at wich the ports start to open, and all this for less than 10$.
Before i get this done, i got to take that snaped rusted bolt, that transfers the air from the tube into the lower intake manifold
Old Mar 24, 2002 | 02:37 AM
yayarx7's Avatar
thats how some of the 2nd gen guys do it, as I understand.
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
Engine stand ready
Aug 14, 2015 10:26 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
