downdraft weber jet suggestions
Old Nov 28, 2006 | 11:51 AM
Wankel Warrior's Avatar
I have a 86 6 port 13b with a street-ported engine ....i just got a downdraft weber set up and i do not know what jets to put in it please help!!
Old Nov 28, 2006 | 03:24 PM
speedturn's Avatar
What size venturi do you have in the carb? The venturies are replaceable on the Weber, and the size will affect the jets that you need.
Old Nov 28, 2006 | 07:52 PM
jgrewe's Avatar
GET OFF MY LAWN
You should be able to see the size in the top edge of the venturi. I'm assuming this is a 48IDA, you should have somewhere around a 38 to 42mm venturi in there depending on what it was sized for.
Old Nov 28, 2006 | 11:53 PM
Your right it is a 48IDA and i reads 37 when u look way down into the barrels
Old Nov 29, 2006 | 02:10 AM
Siraniko's Avatar
RX for fun
I have a feeling that your IDA is off the shelf item. 37 is too small for street use. You have go up to at least a 40, 70 idle, 250+ needle/seat, 150 air and 200+ main plus total 3 progression holes per barrel. Play with jets and work your way up
Old Dec 1, 2006 | 02:44 AM
thanx bud i will try it out
Old Dec 1, 2006 | 09:56 AM
jgrewe's Avatar
GET OFF MY LAWN
Venturis where hard to find a few months back we ended up going with some Gene Berg made units.
dona1326cosprings7
Oct 29, 2015 06:47 AM
Jmolina0163
Oct 3, 2015 10:04 AM
NLPerformance
Oct 2, 2015 07:11 AM
