good or bad compression?
Old Nov 20, 2006 | 12:03 AM
ihumplegs62's Avatar
https://www.rx7club.com/showthread.php?t=598192
what do you guys think? the shop it was built at has a pretty good rep, but the only thing that i think is weird is the compression. its just been rebuilt but it only has 87/85 compression. he makes it seem like when the motor gets broken in the compression will be higher , which doesnt make a whole alotta since to me but then again i dont know to much about rotaries. if you guys can give me your in put that would be great.
thanks in advance!
Old Nov 20, 2006 | 12:25 AM
neodriftout's Avatar
Kabooski is a well known member I doubt he would BS you, still higher comp after engine gets broken in does sound fishy. Getting a backup motor??? What about that radiator???
Old Nov 20, 2006 | 12:27 AM
rogrx7's Avatar
Turbovert done.
compression will be low after a rebuild. Kabooski is the man. You'll be fine.
Old Nov 20, 2006 | 12:28 AM
TwEaK's Avatar
Rotors? What Are Those?
no Kabooski is correct after the motor gets broken in a full lets say 1500 miles properly broken in should be higher than 90 you should be good.... ummmm and not bashing or anything but what does a radiator have anything to do with compression?
TwEaK
Old Nov 20, 2006 | 08:13 AM
leatherface24's Avatar
I think he just means keeping it cooler thats all.........it IS a rotary after all
Old Nov 20, 2006 | 10:23 AM
Noah knows what I mean. Its an inside thing.
Old Nov 20, 2006 | 10:25 AM
Whizbang's Avatar
Respecognize!
hell your engine has lower compression when its cold that when its warmed up.
Old Nov 20, 2006 | 07:16 PM
yeah im going to get a extra one when my motor goes.......... which im thinkin might happen at the next drift event but who knows haha. and as far the the heating issue, that has been solved by jared aka leather when he showed me this air scoop for the radiator. its for a miata, so there was some fab work, but fixxed all my overheating issues.......... so far that is haha
http://www.bellengineering.net/Pages...ata_parts.html
Old Nov 20, 2006 | 07:18 PM
TwEaK
thanks for the info. im going to pick it up sat :
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
JZW
3rd Gen General Discussion
29
Dec 21, 2016 11:23 AM
bb6guy
Aug 12, 2015 03:29 PM
