oil pan/shifter?
Old Nov 12, 2006 | 06:52 PM
gear_grinder's Avatar
Don't hate my V8
oil pan/shifter?
i've got two questions here, is the oil pan the same between N/A and turbo or not and the shifter in my TII is a little lose but it actualy turns slightly when changing gears, its kindof like this.
1 3 5
l l l
l l l
l l l
/ l \
2 4 R
It actualy turns slightly when in 2nd and reverse by the indicated slashes. how would i fix this.
Old Nov 12, 2006 | 06:57 PM
Akota's Avatar
Mine does that too some. I think you need to replace the bearings in it, also the spring between left and center. Least thats what I was told. There are 2 other threads about loose shifter, might wanna checkem.
Also, do you know where I can get a new oil pan btw XD
Old Nov 12, 2006 | 06:59 PM
tuns0ffun65's Avatar
bushings my friend, bushings, the bushings are bad
Old Nov 13, 2006 | 11:59 AM
Don't hate my V8
so the shifter problem some what solved but i need to know if there is and differnce between the N/A and TII oil pans because mine is shot and i need a new one.
Old Nov 13, 2006 | 12:59 PM
skizzle84's Avatar
Yea I also need to know the differences between the two oil pans.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
