ecu question
Old Nov 12, 2006 | 05:35 PM
betterthanpistons's Avatar
ecu question
can i put a ecu for a 87 tubro on a 87 non turbo rx7 is there anything to gain from it?
Old Nov 12, 2006 | 05:38 PM
FCKing1995's Avatar
Rotary Slave
problems
Old Nov 12, 2006 | 05:43 PM
HAILERS's Avatar
HAILERS
Nothing to gain at all. It should start though. And run.
The turbo ECU is meant to run with 550 cc fuel injectors. The turbo ECU is not geared to see the output of a non turbo pressure sensor. The voltage output of a non turbo pressure sensor is NOT the same as the output of a turbo pressure sensor.
I've swapped turbo ECU into non turbo 1986 n/a and run for extended periods of time BUT I also used the turbo pressure sensor. Actually it ran pretty well considering all. I wish I'd have had a wideband in that car when I was doing that. Hmmmm. It only takes thirty minutes to reconfigure and I now have a wideband in it. Hmmmmmm.
Skeese
65
Mar 28, 2017 03:30 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
