a good place to buy these wheels
Old Nov 12, 2006 | 02:13 PM
forced inducted fd dude's Avatar
brap brap brap
yea. i cant seem to find a place with much info on the offset and sizes combos for the 5zigen Black Racing Pro-N1 rims, has anyone owned these or sells them i dont want to buy them online and get the order screwed up, and yes i have searched here in miami also and ppl are jerks (selling over price)
Old Nov 12, 2006 | 04:54 PM
Black91n/a's Avatar
Back Racing and 5Zigen are different companies. This site has info on both.
www.edgeracing.com
Old Nov 12, 2006 | 05:10 PM
Mahjik's Avatar
Mr. Links
AutoRND
Old Nov 12, 2006 | 07:02 PM
brap brap brap
i didnt know this the sites iv been on shows these rims with the 5zigens...w/e im lost
Old Nov 12, 2006 | 08:24 PM
Black91n/a's Avatar
Well then they'd be wrong. They do look similiar to the 5Zigen Pro Racer GN+, maybe that's where the confusion came in.
As for what size to get there's a few possibilities. The 16x7 35mm offset, the 17x7.5 35mm offset (tight on the inside), the 17x8 31mm offset, the 17x9 18mm offset (tight on the inside, will require wider front fenders, rolling of the rear fenders).
I'd go with the 17x8 31mm offset, that's a very good size.
Old Nov 12, 2006 | 08:38 PM
TRISPEEDFD3S's Avatar
FEED me
If anything jspecusa.com can get them for a good price for you if Rishie at AutoRND can't.
Old Nov 12, 2006 | 10:10 PM
brap brap brap
yea i e-mail'd rishie today no word on him yet
Old Nov 12, 2006 | 10:45 PM
Mahjik's Avatar
Mr. Links
It is Sunday. Not all businesses are open on Sundays.
Old Nov 13, 2006 | 12:27 AM
brap brap brap
yea i thought of that
Old Nov 13, 2006 | 12:40 AM
C2AUTOSPL's Avatar
check there dealers list.
Old Nov 13, 2006 | 08:27 AM
Eggie's Avatar
Originally Posted by Black91n/a
...the 17x7.5 35mm offset (tight on the inside), the 17x8 31mm offset...
The +31 offset moves the rim 4mm toward the fender, but the 8's extra 1/2" width pushes the inside bead 1/4" (6.35mm) back to the inside. Won't the 17x8 be even tighter on the inside?
Old Nov 13, 2006 | 12:09 PM
Black91n/a's Avatar
Yes the wheel will be tigher, but assuming equal tires that stick out beyond the wheel lip (225-235) the 17x7.5 will be tighter on the inside because the tire will stick out further beyond the wheel lip. The whole tire and wheel combo will be further out on the 17x8. The 17x7.5 will probably be ok with 225/45/17's, but it'll be reasonably tight. Fittment is mostly determined by offset, as long as the wheels aren't too wide.
Old Nov 14, 2006 | 01:17 PM
Pat McGroin's Avatar
Sushi ******!
http://edgeracing.com/wheels/black_racing/
This is a local place for me, they have some badass prices when it comes to rims and tires.
Old Nov 14, 2006 | 11:10 PM
NeoTuri's Avatar
The shy megalomaniac
Here are my Pro Racer GN wheels...
17x9.5" +45 offset
275's still fit under the fenders. I'm looking at 315's in the rear for competition, but I might have to deal with the TAs.
You can get them in +12, +22, +38, +45 (this being the hardest to find)
Ordered mine through Discount Tire for approx. $300/ea. They cut me a deal since I had so much trouble getting 17x9 FN01R-C in a +43.
-Edit-
I think the wheels might be +43 not +45, I'll double check.
Oh, and I'm running 2.5" springs for inside clearance
Old Nov 15, 2006 | 12:37 AM
Eggie's Avatar
<snip>
5Zigen's site lists +43 for the 17x9.5. You got 275/40s to fit up front? Wow! Are your fenders rolled? What's your ride height?
Old Nov 15, 2006 | 06:38 AM
NeoTuri's Avatar
That's height from the center of the wheel to the fender, right? I need to measure that.
And no, the fenders aren't rolled. I am just running a 700# spring in the front. The wheels barely clear the screws on the sides of the wheel well by 1-2mm.
Old Nov 15, 2006 | 10:42 AM
Eggie's Avatar
From the ground to the fender lip directly above the hub. 25" from the center of the wheel would be the offroading setup.
Old Nov 15, 2006 | 06:21 PM
NeoTuri's Avatar
Measured it at 659 mm ~ 26"
Old Nov 15, 2006 | 10:51 PM
brap brap brap
damn, im looking for some decent sizes mainly in 16" and 235 tires all around
Old Nov 15, 2006 | 11:45 PM
Eggie's Avatar
Thanks for the info, NeoTuri. Sounds like a 17x9.5 with +45-50 would make 275s a good fit.
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
