no spark???
Old Nov 11, 2006 | 04:21 PM
makoto's Avatar
no spark???
i have an 87 rx7, the problem is that im not getting any spark, however, ive checked the coils and even switched them with another set from an 87 t 2.....and still nothing. the motors spinning, its just not starting. does anyone know of any other methods i should go about using?
Old Nov 11, 2006 | 09:41 PM
Madrx7racer's Avatar
um...........so it's not the coils.........is it making ANY noise? can you post a vid of very DETAILED description?
Old Nov 12, 2006 | 10:24 AM
Aaron Cake's Avatar
Engine, Not Motor
Set the key to IGN and remove the CAS. Leave it plugged into the harness. Spin it with your finger. Do you get spark?
Old Nov 12, 2006 | 04:20 PM
HAILERS's Avatar
HAILERS
IF your tach makes small bumps up/down when you spin the starter, then you have spark.
No tach needle bumps? Is the ENGINE FUSE in the interior good or bad? Bad? Replace same.
Good fuse? Then make sure the fuses in the engine bay are good. The ones called EGI Comp and EGI Inj (series four).
Real sure you have no spark? How sure? Pull a sparkplug wire off and hold it in your bare hands. Other hand touching the bare metal of the chassis or engine. Spin the starter. What were the results?
I wish somebody that has a heart pacemaker would do that. I'm curious if it would effect the pacemaker or recipient of the pacemaker.
Personally, if the fuses were good, I'd do what Cake said above.
Old Jan 1, 2007 | 10:42 AM
--MAstermind--'s Avatar
sigh NO GO no spark and no bounce on the tach...BUT the CAS im testing out worked on another car.....im flabberghasted! lol thanks for the help if anyone else can give me a pointer please chime in!
Old Jan 1, 2007 | 11:24 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the ignition coils for 12V with the key set to IGN. Check on the black/yellow wire.
Old Jan 1, 2007 | 11:39 AM
SirCygnus's Avatar
whats going on?
the airflow meter could be a problem. i tried for a month before i figured this one out on my old 86 gxl.
like an idiot i removed it via the screws and yanked that innerds out. remarkably i still drove it to school. only to die on me. no spark nothing. i got fuel and whatnot, yet erverything was completly in spec.
try unhooking the airflow meter and try starting up the car.
Old Jan 2, 2007 | 12:22 PM
ROGER! we shall give that a shot ill be checking for volage at coils as well...ill be back with the status of the situation!
Old Jan 2, 2007 | 04:58 PM
rx7 FC TII's Avatar
Semper
check you Fuses inside the engine bay....i blew my EGI comp fuse and i was getting no spark either....
Old Jan 2, 2007 | 06:15 PM
stevie1020's Avatar
Gig a Giddy Go
or time for a new ecu i had this promblem in my s4 damn ecu
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
