help on buying a single setup have 3000.00
I am completeley stock I have made my mind up. what is a good turbo for anayware between 300-400 hp and reliable. Also excatly what else to make it all work. What should I try to get used I need some help on this one. any and all help will be greatly appericated.
you are going to need much more than 3k. even if you bought everything used you would need a lot more than 3k.
but if you gather more money up i REALLY like my setup. very reliable and streetable with plenty of power. see sig for details
Start with a boost gauge, then Down pipe, and maybe intake. Get a power-FC, throw a cat back, intercooler, and mid pipe/high flow cat on the car and have some serious fun. Around the time of the IC, I'd start investing in a upgraded pump (bosch 044 imop) and some larger injectors. Should make 300-330rwhp and be fun. Just get it tuned by someone who knows how to tune a 7. At that point, you can decide what way you want to go with your car. CJ
Trending Topics
Originally Posted by EZFD
take the $3k and put it aside untill you have around $10k and then go single, it will be much easier.
Originally Posted by BackyardSog
I hope thats installed. I think im under 5k for mine.
honestly if your just fed up with the sequential system either get a smaller kit like a rx6 or 35r, upgrade your stock injectors ie 1300, and get a powerfc. Keep the boost limited so there is no needs for a ignition ampilifier to help lower your cost. Just an idea.
Originally Posted by GoodfellaFD3S
the thread starter's car is completely stock. He is referring to the multitude of other stuff he is going to need in addition to the turboo kit
That will be a buget combo with gd power gains and probably leave you with enough loose change for a clutch upgrade.
I had BNR stage 2's that was the biggest waste of money i have ever spent on my Rx7. No real power gains worthe the money and the seals went bad and made my car smoke so bad after about five months. the way i see it pay for what you realy want the first time because you will always end up buying it after the stupid part you setteled for in the fisrt place.
at what point is the engine tired? mine has about 40k miles on it, do i need a new motor or will it be ok? it already has a rebuilt tranny and a street clutch and lightweight sport flywheel (or soemthing like that...)
Everytime I drive my FD, I'm just waiting for the motor to pop.
It has 50k miles on the stock motor. I know its getting tired, as it takes more boost to make the power I did a couple years ago...even with putting on larger exhaust, (From 3" to 3.5") different LIM, straighter IC piping etc. Back in the day, it made 407rwhp@16lbs, now its only making 360rwhp@15lbs. Bolth times dyno'd it was on a the same mustang dyno. I don't drive the car much, but its still alot of fun.
CJ
CJ
You oughta get that thing out of there before it goes catastrophicly and takes out your turbo with it.
CJ
CJ
Well, unless it goes it won't be rebuilt. Thats the way wifes work. It still drives...so everything must be allright. Well, thats the way it she thinks. I've thought about pulling the map sensor off, and telling her it let go....but then I'd feel guilty.
I'm not worried about it. When it does go, I'm going to go with a BB T-66 I think, and big street port engine. I'm good friends with Rob at Pineapple Racing, and he can throw something together for me.
CJ
CJ
CJ
CJ
I was thinking about this and if you have fabrication skill and the ability to do your own work it might be possible to take a stock FD to a single for 3k. Granted most items are used and at the best prices you can find but I think it can be done. You won't have the best product available, but you would have a setup for 350-375 hp and be single.
PFC (used) 500
1300cc Injectors (used) 150
Walbro (new) 100
Catback (used) 200
Rad Koyo (used) 200
Manifold (SSAFC) 100
IC (XS Power) 150
BOV (used) 75
T04E 57 or 60 (used) 200
Downpipe/Mid Material 200
Airfilter 30
Boost Gauge 50
Datalogit 300
WBo2 LC-1 200
Tuning (yourself) Free
Fab/Welding (yourself) Free
BOP's 50
AST (removal) 50
Clutch (used) 200
WG 40mm HKS (used) 150
Oil Feed/Return 100
Total 3005
Sell
Turbos/Manifold 200
Solenoids ???
Y-Pipe ???
850cc Injectors ???
End Total >2805
PFC (used) 500
Walbro (new) 100
Catback (used) 200
Rad Koyo (used) 200
IC (XS Power) 150
BOV (used) 75
Airfilter 30
Boost Gauge 50
Datalogit 300
WBo2 LC-1 200
BOP's 50
AST (removal) 50
Clutch (used) 200
Oil Feed/Return 100
Total 3005
Sell
Turbos/Manifold 200
Solenoids ???
Y-Pipe ???
850cc Injectors ???
End Total >2805
. Lets see if i can put up everything i have gotten so far.Used Greddy FMIC w/ HKS BOV - $400.00 shipped
Used TT Supra Denso Fuel Pump - $100.00 shipped
New Apexi PFC w Commander - $900.00 shipped
New T04R w 1.00 hotside - $900.00 shipped
Used Tial 44mm Wastegate - $150.00
New Ebay Turbo Manifold (from other forum Member) - $65.00
New aluminum race radiator from radiatorworld.com - $275.00
Upgraded fuel system from KGparts. com -$500.00
Used MSD 6AL - $80.00
New HKS EZ Boost Controller - $250.00 (I think)
New ACT Clutch w EXtreme Pressure Plate - $450.00
Used Dataloggit - $200.00
Ebay 3" intercooler pipe kit - $100.00
Used Greddy Elbow - $90.00 shipped
HKS Hyper Catback - $250.00
ATp Turbo Coupleers and reducers - $80.00
Misc Gaskets, Hose, Fittings, - $300.00
Total - $5090.00 give or take a little
I have also made some money off of the factory twins stuff. I still have some more to spend on a downpipe and battery relocation. I also have some side projects like relocating the coils, v-mount, and converting a trans cooler into a secondary oil cooler. But all in all i think im doing allright and have saved quite a bit of money.
Skeese
65
Mar 28, 2017 03:30 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
