Oil Cooler Install Tips?
Old Nov 9, 2006 | 06:46 PM
jdonnell's Avatar
Tomorrow I change my oil cooler and hoses. I searched a found alot of stuff but still had a couple questions:
a) I undestand you install the banjo bolt for the long hose first so its easier to install the other end at the oil cooler. Book says 40-51 ft-lbs torque-Is this right since it goes into an aluminum engine and cooler? Seems high. I read its easy to crack the oil cooler too.
b) Do you use thread sealant?
Any tips?
Old Nov 10, 2006 | 09:24 AM
Aaron Cake's Avatar
Engine, Not Motor
The banjo bolts are straight threaded so that torque is not a problem. An NPT fitting might crack because of the taper.
No sealant, but you need to use new crush washers.
Old Nov 10, 2006 | 05:36 PM
jdonnell's Avatar
Thanks, I didnt know that about the threads. Good info. Didnt get around to it today but did get my tranny & diff fluids changed and fuel filter.
I was looking and wondered if the oil needed to be drain from the engine? The hoses into the engine look higher than the pan level. I only have 500 miles since I changed it last.
Old Nov 12, 2006 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Nah, you don't need to drain it.
Old Nov 12, 2006 | 11:42 AM
jdonnell's Avatar
I drained it just in case.
Now, when you tighten the lines at the oil cooler is it better to tighten them before you mount the cooler? The rubber on the bracket flexes quite a bit and Im afraid I'll crack the cooler neck. I had to dremel the old brackets out because they were gone/rust.
Old Nov 12, 2006 | 04:33 PM
Aaron Cake's Avatar
Engine, Not Motor
I always mount the cooler before tightening the hoses. The hoses only really fit at specific angles so it is hard to get them installed with the cooler out of the car. The cooler tends to move a lot when tightening the hoses but I've never ripped a mount.
Old Nov 12, 2006 | 05:17 PM
jdonnell's Avatar
I'll try it that way. I searched all day for the one crush washer at the front cover and stainless nuts to mount the cooler. Found the nuts but not the crush washer so I guess I'll hit the stealer tomorrow.
I fitted the lines finger tight and everything fitted really easy. I'll tighten it tomorrow once i get the washer
This job was tougher than I expected. Things were rusted in place and I had to cut out the bracets. Sand/garbage in and around the cooler and evaporator was unbelievable too.
Thanks for the info
Old Nov 12, 2006 | 05:19 PM
spot_skater's Avatar
The Cause of Death
I wound up having to get my crush washers straight from Mazda
Old Nov 13, 2006 | 04:19 PM
jdonnell's Avatar
Yep, 9956-41-600.
Old Nov 13, 2006 | 04:33 PM
zionfarm's Avatar
Military Rotary Guru!!!
Me 2 and when i installed the Brand new crush washer it stilled leaked. Then i went to tight and must have stripped it and it's leaking more than ever.
Old Nov 14, 2006 | 04:34 PM
jdonnell's Avatar
Zionfarm, did you have the right crush washer? the front cover washer is different size from the banjo bolt washers. That's my worry that I'll have a leak. I should get the washer Friday and I'll see how it goes.
FD7KiD
15
Feb 26, 2021 10:12 PM
