Rotary Drag Racing The place to post your racing stories and info
tire pressure
Old Nov 8, 2006 | 09:48 AM
matty's Avatar
tire pressure
does anyone know what is the lowest tire pressure u can run in regular street tires? Meaning toyo t1-s not drag radials.
Going racing this weekend and with this cold weatehr i cant get traction at all so i want to run as low tire pressure that i can safely.
Old Nov 8, 2006 | 05:28 PM
matty's Avatar
anyone.....Lupe?
Old Nov 8, 2006 | 10:01 PM
Busted7's Avatar
Will work for horsepower
Low air pressure on street tires does not always help, sometimes higer pressure works better. You need to try settings at the track to find what the best is.
Old Nov 9, 2006 | 06:28 PM
Bacon's Avatar
IRS 4 Life
With radials this is kind of what happens when you drop pressure
Maybe knock them down 5lbs, but for the most part, there’s no point. I realized after I was making decent power, breaking Toyo 275 T1's loose in 3rd, there’s no more point to a traditional radial on the strip
Bias-Ply slicks act differently to lower pressures, as do the drag radials
Old Nov 9, 2006 | 06:39 PM
matty's Avatar
i am at that pt now with 245s and only 360 rwhp. i find i myself backing off the gas on the launch ,towards end of s1t gear and again when i shift from 1st to second. its a joke.
Old Nov 9, 2006 | 08:26 PM
Dan Schechter's Avatar
JIGSAWRX7
Ditto.
13
Jan 9, 2018 11:19 AM
yetter227
20
Sep 5, 2015 11:57 PM
