What SCCA class would I be in?
Old Nov 1, 2006 | 06:49 PM
Rotofire's Avatar
Yea, I'm working on it...
Question What SCCA class would I be in?
I've got aftermarket suspension, intake, exhaust, and radiator. So, what SCCA class does that put me? Anyone?
Old Nov 1, 2006 | 06:54 PM
rynberg's Avatar
You'll have to be more detailed than that on your suspension mods....
Old Nov 1, 2006 | 07:04 PM
Rotofire's Avatar
GAB super R 8-way adjustables with lowering springs...eibach i think.
Old Nov 1, 2006 | 07:12 PM
bean13's Avatar
unfortunatly your somewhere between ITS and Showroom Stock. Showroom stock means stock. ITS is a bit more than what ya got,, suspension is pretty much unlimited but engine has to be essentially stockinside. Grab a GCR for your sanctioning body and read through that and it will tell you the mods you can do. Good luck in your racing!!!!!!!!!
Old Nov 1, 2006 | 07:17 PM
Rotofire's Avatar
thanks!
Old Nov 1, 2006 | 07:27 PM
Black91n/a's Avatar
Autocross I presume? In which case there's no Showroom Stock or ITS classes, besides, SS is for cars less than 5 years old, and ITS is for FC's.
For the FD, you'd be in SM2 I think, maybe ASP, it's dependant on what you've done, look up the rules and decide for yourself. In either case you'll probably be seriously outgunned by cars prepped to the limit of the rules (depending on who shows up).
Old Nov 1, 2006 | 07:33 PM
dgeesaman's Avatar
If you're talking autocross, the car is ASP because of the springs and intake. If you had stock springs and stock airbox (K&N filter is ok) you could be in SS. Not sure about the radiator.
Obviously you should take time to read the rulebook though and verify everything yourself.
Dave
Old Nov 1, 2006 | 07:51 PM
Sandro's Avatar
For autox, non-OE radiator put you out of both SS and ASP
Old Nov 1, 2006 | 08:15 PM
dgeesaman's Avatar
Wow, that's a little surprising. But good to know.
Dave
Old Nov 1, 2006 | 08:19 PM
rajeevx7's Avatar
2 FD's since '98
You need Acrobat:
http://www.scca.org/_filelibrary/Fil...solo_rules.pdf
Is that ALL you have? They consider things like steering wheels, seats, battery placement, rubber etc...
Old Nov 1, 2006 | 09:46 PM
dhcernese's Avatar
Dan Cernese
radiator bumps you all the way to "prepared"
Yes, it sucks. There is currently people requesting to allow after-market radiators in SP but probably not for 2007. That means you get to lose in BP. Or, you can just run in ASP like a few people I know.. ..a local region can be as flexible as they want to be and let you run ASP... until you run into folks at a divisional or national event; then you'll get protested out of ASP.
Old Nov 1, 2006 | 10:41 PM
XxMerlinxX's Avatar
Team Benjos Captain
Under what rule does his car not conform to ASP? I'm not seeing anything that mentions aftermarket radiators.
Old Nov 1, 2006 | 11:27 PM
C. Ludwig's Avatar
www.lms-efi.com
If it doesn't say you can then can't.
Old Nov 2, 2006 | 06:44 AM
dhcernese's Avatar
Dan Cernese
Beginning of SP, ~2nd paragraph:
"A vehicle may compete in Street Prepared Category if the
preparation of the vehicle has not exceeded the allowable
modifications of Stock Category, except as specified below."
As C. said, the golden rule in Solo is
If it doesn't say you can then you can't.
Old Nov 2, 2006 | 10:48 AM
SPICcnmGT's Avatar
BP, why not SM2?? Am I missing something?? There is not going to be any competition in BP due to lack of competitors.
Old Nov 2, 2006 | 10:57 AM
dhcernese's Avatar
Dan Cernese
radiator is BP
Yes, you are, the golden rule: If it doesn't say you can then you can't. Do you see anything in the SM description that says you can have a non-stock radiator? (I don't). Even if it did how would you compete against the 3-rotors? Good luck!
Old Nov 2, 2006 | 11:47 AM
dgeesaman's Avatar
Uh-oh, I think I've been running aftermarket tire stem caps all this time.
The interesting and odd thing is that aftermarket radiators would have very little effect in Autocrossing. The runs are too short.
Dave
Old Nov 2, 2006 | 12:34 PM
AMRX7's Avatar
Radiators are considered part of the powertrain in SM, so are unrestricted. Use whatever you want.
-Andy
Old Nov 2, 2006 | 12:36 PM
dhcernese's Avatar
Dan Cernese
you jest!
Dave
That's because you don't think like a Solo competitor :-)
What advantage can changing a radiator have OTHER than cooling?
It it's lighter, then you save weight. If it changes airflow, then you improve cooling or maybe charge intake, etc.
In other words, people are concerned that SP cars will run with smaller radiators (not larger) just like they mostly run with smaller and lighter batteries in some classes.
p.s. on the stem-caps, these are of course covered under "Stock":
"Accessories, gauges, indicators, lights and other appearance,
comfort and convenience modifications which have no effect on
performance and/or handling and do not materially reduce the
weight of the car are permitted."
Old Nov 2, 2006 | 12:43 PM
dhcernese's Avatar
Dan Cernese
SM looks pretty darn open
You mean "Drivetrain and related components (induction, ignition, fuel systems, etc.) are unrestricted except for the following limitations ..." my mistake, I'm not familar with SM2.
That is the same rule that has allowed folks to build 3-rotor and big turbo cars for SM2, which is somehow easier to compete against than BP? :-)
Old Nov 2, 2006 | 01:42 PM
SPICcnmGT's Avatar
Thats exactly what I was thinking with SM2. You can change the engine, turbo charge a non-turbo car, but you can't change the radiator?? That wouldn't make any sense at all.
Old Nov 2, 2006 | 02:22 PM
Sandro's Avatar
Compliance to National rules is not mandatory at local level. Most likely, they will let you run in ASP, despite the radiator - usually tolerated. You may run in any higher class of course, including BP or SM2, but then will compete against car with significantly more extensive mods.
Sandro
3rd Gen General Discussion
24
Dec 30, 2017 03:35 PM
Broke_A_Baller
Race Car Tech
Sep 24, 2015 09:27 PM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
