Will a pop off valve save me from boost creep?
Old Mar 4, 2002 | 05:30 PM
sublimeracing's Avatar
Question Will a pop off valve save me from boost creep?
I was wondering if a pop off valve (not a BOV) would save me from boost creep? I have an 88T2 and am getting a downpipe, presilencer, and midpipe running to dual apex N1's. I am hoping on running between 10-12psi. I just spent $8,000 on all new engine parts. About everything got replaced.stupid pd Anyway I don't want to risk blowing my engine. I know I need to rewire or get a new fuel pump but was wondering if this will prevent boost creep with my stock waste gate?
Old Mar 4, 2002 | 05:33 PM
Dyre's Avatar
Your Opinion is Wrong
Pop-off vavles are a last step saftey measure, not a boost controller.
What year is your TII
If you spent $8k on a damn motor you should have at least taken the couple hours to port the **** out of your wastegate, or convereted the the seires 5 mani and turbo for $300 if you have a Series 4 TII.
Old Mar 5, 2002 | 11:33 AM
Old Mar 5, 2002 | 12:29 PM
RETed's Avatar
Pop off valves are very hard to set correctly (at least the HKS ones).&nbsp Or more accurately, the pop off valves do not trigger consistently at the same boost level.
As Dyre said, it's a last resort safety device.&nbsp Don't try and set it very close to your maximum boost levels.
Port your wastegate - this will minimize boost creep.
-Ted
Old Mar 5, 2002 | 05:03 PM
How do you set them up? i know it sounds daft but how can you tell if its set correctly?
Is it a case of seting it to a level that is max for your car then run under it?
Do you have to hit the limit to test it?
What happens if its to high?
Old Mar 5, 2002 | 06:55 PM
Freaky Monkey007's Avatar
Isnt a pop off valve to keep the exact opposite of a BOV?? It keeps excess pressure from hittin the turbo right??
Old Mar 6, 2002 | 04:06 PM
RETed's Avatar
Adjust...pound your car, watch boost gauge...stop, adjust...do it all over.
Yes, basically.
No.&nbsp I would normally adjust it down till it triggers and back it off just a tad.
If it's set too high, it will never trigger...
-Ted
Old Mar 6, 2002 | 04:10 PM
RETed's Avatar
Think of a pop-off valve as a safety release valve.&nbsp Back in the day (even now), there were chances that a wastegate can get stuck close - this means instant stratosphere boost!&nbsp The pop-off valve is designed to blow off to prevent damage from such an event...
-Ted
Old Mar 6, 2002 | 04:13 PM
RICE RACING's Avatar
There is a company called NIZPRO in Melboure Australia that does not use wategates at all on their cars, they conrol boost via a pop off vale electronically controled via a MOTEC engine managment computer.
I have personally seen it on a few of their cars, It does work very very well and saves the worry of adding extra pipes etc to run a WG, only problem is you need a MOTEC to run it this way.
I believe if it was done in a mechanical (not via ECU) way that it would be inferior to a WG system.
Old Mar 6, 2002 | 04:18 PM
RETed's Avatar
That's almost like running a wastegate on the compressor side.&nbsp I've seen this done on a turbo'd Chevy Impala SS that popped up at the SEMA 99 show...
It made me cringe to think the turbo overspin it's going to attain when it does trigger!&nbsp I guess if you're running BB centers it should stau together, but 150,000+ RPM is not my idea of keeping everything safe!
-Ted
Old Mar 6, 2002 | 04:25 PM
Very good point !
She would be a "free spinner" at WOT @ 8000rpm with no bypass on the turbine !
I shudder to think what rpm's it would go to ?
Though they are a linked system....so if PR remains under contol, then rpm should be in check as well.
Old Mar 6, 2002 | 04:37 PM
maxpesce's Avatar
Ex fd *****
Using a POP-OFF valve alone to control boost is a good way to destroy your turbos - A wastgate reduces the amount of exhaust energy spinning the turbo, a BOV just releases charge air and nothing to reduce the exhaust energy reaching the turbine, thereby allowing the the turbo to overspeed.
Old Mar 6, 2002 | 04:47 PM
I agree with that theory as well, I wonder why some companies are doing it this way though?
Am I missing something ? I have to agree, on the face of it, as when a blow off valve opens PR goes to 0 but the turbo still spins at 50 000rpm or more for quite a while ...... Hence with a POP system the turbine will have to over speed if there is no reduction in mass flow rate to the turbine (which there is not).
I think I am right? , oh it's too early for me
Old Mar 6, 2002 | 07:01 PM
peejay's Avatar
Old [Sch|F]ool
What kind of turbine wheel/housing do they run?
rgordon1979
40
Mar 15, 2022 12:04 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
SakeBomb Garage
Oct 9, 2015 10:05 PM
Nosferatu
Sep 5, 2015 02:13 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
