irrattic idle 1400-1600 RPM!
Old Mar 4, 2002 | 04:11 PM
tweaked's Avatar
this thing just started on friday ( I didn't drive the car all wekend)
I drove to work everything was fine. when I got back home, the idle was much higher and fluctuating between 1400 and 1600 rpm. I did change the upper manifold two weeks ago but this just started. I have no idea what it is. it doesn't do it until it reached normal operating temp either. any ideas?
by the way the car is an 88 n/a with a few mods. I can list them if you like.
Old Mar 4, 2002 | 08:45 PM
mazdaspeed7's Avatar
mad scientist
first, check for vacuum leaks. Did you miss any vacuum hoses, and sensors you forgot to plug in, etc.
Then check the nuetral switch and clutch switch.
https://www.rx7club.com/forum/showth...463#post483463 This might be of interest to you.
Old Mar 4, 2002 | 09:42 PM
it happens to me too... just before it warms up... then goes to 1100 rpm as idle.. but i always be messin around with the idle switch.. and i have a vacuum leak somewhere or a bad bac
24seven_dada
20
Nov 10, 2018 12:03 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
Im faster
Sep 10, 2015 04:38 AM
The1Sun
Sep 7, 2015 10:21 PM
