Sponsored by: CARiD
Help with OMP setup?
Old Oct 25, 2006 | 08:15 AM
13BT_RX3's Avatar
The General RE
I have a Cosmo 13B-REW with a 12A front cover. I was considering using an externally oil source for my OMP to pull 2 cycle oil instead of engine oil. Like:
http://rotaryaviation.com/oil_injec...mp_adaptors.htm
Should I use a linkage to control the OMP or fix it open?
If I set the pump to run full bore can the 12A OMP put out enough oil for my application?
Should I just use premix?
Are there any OMP tricks or modifications anyone can share?
Old Oct 27, 2006 | 12:44 PM
trochoid's Avatar
Old Fart Young at Heart
Afaik, the RA pump has no provision for throttle linkage. Not that familiar with the Cosmo engine, does it have the mechanical or electronic mop? If it's electronic, you have other issues to deal with.
When comparing the mop output tests between the 12A and say an S4 TII, there is a big difference in volume. By the time the US version of the REW came over, the mop volume was reduced from the TIIs, especially at lower rpms.
My understanding is the mechanical mops are based on throttle position, while the electronic ones are controlled by the ecu and the RA one is rpm based as it is gear driven by the engine.
Old Oct 27, 2006 | 05:23 PM
13BT_RX3's Avatar
The General RE
The Cosmo engine came with electronic mop with 2 discharge lines. I was going to track down a GSL-SE front cover, but the 2 line thing led be to using a 12A cover I already had. There are no provisions for a linkage to the new mop. I was thinking about using a cable or just fixing it open as RA recommends. I guess my main concern is not giving the seals enough oil. How much do FDs put out? With that info I can test mine and compare. If it is less I suppose premix would be the way to go unless there is away to modify the 12a mop.
Old Oct 27, 2006 | 06:24 PM
MOBEONER's Avatar
It's finally reliable
use the stock omp to runn premix,tap into the pump like i did my turbo II
Old Oct 27, 2006 | 09:30 PM
13BT_RX3's Avatar
The General RE
So, you run the MOP fed with 2-stroke oil instead of pan oil. How long have you used this setup? Have you had any issues with it so far? What is your the 2-stoke oil consumption rate like? Do you run a linkage or is the MOP fixed at preset position?
20B Forum
21
Mar 22, 2022 01:00 PM
cewrx7r1
15
Aug 6, 2018 11:41 AM
BLK 93
11
Sep 9, 2015 10:56 AM
