what could be happening??
Old Oct 23, 2006 | 05:51 PM
ronbros3's Avatar
Ran a customers car 93 FD on DYNOJET, made only 280rwhp at 7000, but made 275 TQ, at 4500, hers the mods, medium street port, Atkins seals, GT4085 67mm inlet, .95 turbine hsg, 4" exhaust all the way, FMIC 3" pipes, 850s-1600s, AFR 11.5, 15 degrees at 16lbs. MICROTECH LT10s, customer wanted only 93 oct. no race gas! could the turbo be to big and not reaching efficeancy range at 16 lbs. am told that it should be at least 20psi up to 35psi. but whats up the with the HP and TQ. almost the same on a rotary, dyno operator said never seen that before. anybody??
Old Oct 23, 2006 | 06:20 PM
pp13bnos's Avatar
Pineapple Racer
Man, that is low. By 15 degrees, you mean the leading timing way up in the RPMs correct? Where does the boost gauge vacuum/boost get its reading from? How does the car feel, it should accelerate pretty good....that car should be pushing 400rwhp without to much problem. You guys do a compression test yet? CJ
Old Oct 23, 2006 | 06:46 PM
rogrx7's Avatar
Turbovert done.
make sure u have compression on both housings.
Old Oct 24, 2006 | 03:40 AM
AnthonyNYC's Avatar
Stay tuned...
When you ran the car on the dyno, did you set the bottom choice to "rpms or engine speed" or "speed" (meaning speedometer)
If you had it on engine speed/rpms, ask him to swap the lower choice to speedometer and see what you get.
Anthony
binz
Oct 2, 2015 03:52 PM
musker
Oct 1, 2015 05:58 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
