engine has mind of its own!
Old Mar 3, 2002 | 09:24 PM
theNeanderthol's Avatar
the torquinator
I was driving this evening and i punched it and shifted at 6800rpm. After the clutch was in for the shift and my foot COMPLETELY OFF THE GAS and the engine revved up to 7600 rpm! What the heck is going on?! I tried several more close to redline runs and it did the same thing. I thought the throttle was just sticking open or something so I ran it to redline with the clutch in and it acted normally. What is it? Ignition, timing, carb?
Old Mar 3, 2002 | 09:52 PM
Pele's Avatar
Right near Malloy
Secondaries sticking open under vacuum?
Old Mar 3, 2002 | 09:57 PM
the torquinator
Maybe so. Solution?
Old Mar 3, 2002 | 10:04 PM
Pele's Avatar
Right near Malloy
Clean the linkage.
Old Mar 3, 2002 | 10:08 PM
the torquinator
Thanks Pele. I'll try it. Keep the ideas coming guys, just in case that isn't it.
Old Mar 3, 2002 | 10:17 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Sounds like a possibility, but the only way it could be so is if the secondary shaft return spring was unhooked.
The oil metering pump linkage could be binding, too.
Check the juice in your clutch?
Old Mar 4, 2002 | 12:29 PM
the torquinator
clutch fluid is good. maybe I'll just lube up the whole thing and take it for a test drive later.
Old Mar 4, 2002 | 06:55 PM
the torquinator
cleaned and lubed the linkage no success. Still revs up after I let off the throttle. Any more ideas?
Old Mar 5, 2002 | 12:02 AM
Sterling's Avatar
The dashpot is probably sticking.
Microtech
30
Apr 23, 2016 06:37 PM
driftfcbuckey
The Bad & Fugly Members
Dec 2, 2015 05:48 PM
rexone
The Bad & Fugly Businesses
Aug 23, 2015 06:24 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
