Help! The car has nothing above 4K
Old Mar 3, 2002 | 01:58 AM
Crazy_Jake's Avatar
The car pulls good up to 4000 rpm then it stops pulling and has to work to get through the higher rpm's. Once the rpm is about 5k, it starts to sputter, and if I let off the throttle it pops, like a little backfire. And if I downshift on the highway to 3rd gear, and the revs go to about 6500 to 7000, the exhaust sounds like a machine gun and the car sputters and jerks pretty bad. It's pissing me off cause I had a 60-ft time better than a guy running mid 13's, but with my car like this I end up running my best e.t. of......15.58!!!!! On the highway civics with only exhaust and intake are burning me! I'm running two K&N filters (not cold air box), cat-back, downpipe, and mild port. Running a PFC tuned by Shane Racing. They wouldn't program it to lean would they? My guess is I'm running rich, I hope.
Old Mar 3, 2002 | 02:54 AM
cash money's Avatar
Old School Member
have you tried the basics like running injector cleaner and checking your plugs?
Old Mar 3, 2002 | 12:18 PM
Crazy_Jake's Avatar
Injectors were just balanced and blueprinted by RC. Plugs are relatively new less than 3K. May be fouled if I'm running rich.
Old Mar 3, 2002 | 12:26 PM
lane_change's Avatar
It has begun
Are your 5th and 6th ports opening up? My friends FC had problems when he installed a race pipe in place of the DP and Cat because his Air Control Valve could not register anything because he did not have a block off plate yet so he ran out of power after about 4k.
Old Mar 3, 2002 | 12:51 PM
Crazy_Jake's Avatar
Please, explain this in greater detail. 5th and 6th ports?
I didn't know you needed blocking plates when you installed a downpipe.
Old Mar 3, 2002 | 01:00 PM
It has begun
His FC has a pipe that runs form the ACV to a port on the exhasut, I think at the cat. When he installed the race pipe there was nowhere to hook the other pipe off so it's been running open. He said he has to take the ACV off and install a block off plate so it can register pressure to open the 5th and 6th ports. I haven't talked to him in over a week but he said he ordered the block off plate and was installing it last week. I'll ask him. I also don't know if the FD is any different then an FC as far as all that goes.
Old Mar 3, 2002 | 01:04 PM
Crazy_Jake's Avatar
Does the ACV come off when you remove the air pump?
Old Mar 3, 2002 | 01:38 PM
RecKleSs's Avatar
Adrenaline
How much boost are you hitting after 4000 RPM?
Old Mar 3, 2002 | 01:46 PM
Crazy_Jake's Avatar
The boost is dropping off because the car is running like ****. Probably dropping to like .45 or somewhere near there.
Old Mar 4, 2002 | 03:13 AM
Crazy_Jake's Avatar
Does anyone else know anything about blocking plates when installing a downpipe. And can anyone explain what is this "5th and 6th ports"?
Old Mar 4, 2002 | 03:17 AM
It has begun
I got my friend to get on the forum. He is the one that has teh FC I was talking about. You can send him a PMor something. I bet he is aspleep right now but he should check tomorrow. He is my_jdm_rx7 you can try. He can explain it better.
Old Mar 4, 2002 | 03:19 AM
Crazy_Jake's Avatar
Many thanks!
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Junkee
Aug 15, 2015 01:57 PM
