Microtech Can ne 1 make a Map?
Old Oct 2, 2006 | 05:55 AM
Mixed_88TII's Avatar
PeNfIfTeEn
Jus wondering if anyone or is it possible for a map to be made for my car if i gAve the specs of my engine... i want to run around 10-12lbs....
The car will be used as a mild daily drive... but mostly driven to cruz aruond look for girls...lol
But seriously is it possible?
Old Oct 2, 2006 | 08:51 AM
C. Ludwig's Avatar
www.lms-efi.com
Someone can get you started but it will still need to be tuned. Engines and setups that are exactly identical will need slightly different tunes. The best thing to do is find a tuner in your area and bite the bullet now before something gets damaged.
Old Oct 2, 2006 | 12:54 PM
Aaron Cake's Avatar
Engine, Not Motor
What he said. The base map that comes with the unit should be good enough to start the car and drive it out of boost, but it will have to be tuned to your specific configuration. That can only be done by someone with physical access to the car and who knows what they are doing.
Old Oct 3, 2006 | 02:26 PM
fastcarfreak's Avatar
3rd motors a charm I hope
you will find that one of the only problems that i have come across with microtech, is that you can not save maps and such. You have to put everything in manually
Old Oct 12, 2006 | 04:36 PM
dradon03's Avatar
Derwin
I don't get it you mean that you have to have a laptop connected at all times?
Old Oct 12, 2006 | 08:32 PM
C. Ludwig's Avatar
www.lms-efi.com
No. What he is saying is that MT does not support saving maps to a file. The only way to save a map is to save it on the handset or to a laptop adapter. Either has the capacity to hold 4 maps. If I have a map that works great on setup X and you happen to have exactly the same setup I can't email you a file that contains my map. I must physically bring the device that I have it stored on (MT handset or laptop adapter) to your ECU and download it from that device.
Follow the MT forums and their techs continually say they're working on changing so you can save to a file. My guess is that they make enough profit from selling laptop adapters that they're reluctant to change.
Old Oct 12, 2006 | 10:44 PM
dradon03's Avatar
Derwin
Thanks for the clear up.
Old Oct 13, 2006 | 09:08 AM
Aaron Cake's Avatar
Engine, Not Motor
Sharing maps is evil. It blows up engines.
Old Oct 27, 2006 | 03:02 AM
RotaryEvolution's Avatar
Sharp Claws
isn't all that difficult to write down and type out a full map.
no i will not give you my map because i will explode like your engine does after the tuning is insufficient for your setup and i get blamed for putting up a 'bunk map'.
everything in this thread is true, sharing maps is a very bad idea. every engine is unique in and of itself so even identically setup engines will have different requirements so what works for someone may not work for you with ill consequences.
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
