Sponsored by: CARiD
Pulley for Crank Angle Position
Old Sep 22, 2006 | 08:10 PM
atihun's Avatar
The 3rd gen main pulley has the crank angle indicator as a seperate piece behind it.
I could not find any information if it is required to be put on a specific way. I know that it can only go on 1 of 2 ways (up or down), as the holes are offset, but does this have to be aligned with the rotors in some way? Or it doesn't matter?
I was thinking it would matter because it's used to detect the e-shaft angle, and front rotor position (from the FSM).
Thanks!
Old Sep 23, 2006 | 10:24 AM
BuckyFD3's Avatar
GT4088R
It only goes on 1 way. The holes are drilled so you cant put it on wrong so dont worry.
NEWGENRX7
Jun 26, 2019 12:20 AM
FlatVermin
22
Sep 27, 2015 05:42 AM
localized
Sep 16, 2015 12:18 AM
Monsterbox
Sep 11, 2015 03:29 PM
