Power FC Advanced injFrSec
Old Sep 15, 2006 | 12:31 PM
sdminus's Avatar
Cant be bothered anymore
Advanced injFrSec
What do these numbers represent. Voltage ?
Scott
Old Sep 15, 2006 | 04:27 PM
cewrx7r1's Avatar
Eye In The Sky
I do not know what it is a direct measure of, but it and it's partner (InjFrPr) need to be viewed together with the chart function. Then they will show how the injectors interact when the secondaries come on-line. I also view Inj Duty Cycle along with them to setup the injectors for a smooth transistion.
Attached is the results of CORRECTED 550/1600 sequencing.
Old Sep 15, 2006 | 04:42 PM
sdminus's Avatar
Cheers Chuck.... Mine is a lot differant to that. 850,850
Old Sep 16, 2006 | 06:48 PM
cewrx7r1's Avatar
Eye In The Sky
You need to adjust your chart values so that you have two distinct and seperate
lines for each of the injectors like mine looks like. Then it will be easier to see what is happenging.
The parameter with the most affect on staging is the
"Secondary Transistion (ms)" value.
Attached is my UNCORRECTED 550/1600 sequencing.
Unfortunately the PFC/DL does not give you perfect injector control, as my CORRECTED is still not perfect, but the best I can get it.
The rule of: (850/ new inj) X 1.5 does not work!!!!!!!
Info on this is part of my DL/PFC tuning notes package.
Old Sep 17, 2006 | 02:45 PM
sdminus's Avatar
Thanks Chuck i will look into it. I have your document on my laptop.
Scott
Rotate86
May 18, 2018 02:44 PM
Sethix
Nov 3, 2017 11:48 PM
SRTx781
Dec 19, 2015 07:30 PM
James Knox
Oct 5, 2015 07:56 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
