Three important questions.......
Old Sep 13, 2006 | 10:34 PM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
1) Can a GSL-SE tranny fit a Cosmo 13B Motor?
2) What is the best tranny for 500 whp?
3) What is the difference between SE and 79 12A Tranny?.... Length???
Old Sep 14, 2006 | 09:17 AM
1. NO..the cosmo flywheel and starter will become an issue or some machining will be required. Shaft spline on the se tranny is smaller than a cosmo clutch..
2. i have seen the turbo II and 93 and up transmisions take a beating...So without going into special use i would stick with the OEM.
3. SE and 79 tranny differ in the tail end. You can swap the different tail parts of the tranny and vice versa. The 79 tranny has the shifter aprox 3 inches shorter.
SE tranny is a little stronger than the 79..
Old Sep 14, 2006 | 11:52 AM
RX7UP's Avatar
1) would I have to put a SE flywheel and starter on the cosmo motor in order for it to work?
2) How much does a TII and FD tranny sell for?
3) When you say shifter is shorter by 3 inches. You mean closer to the firewall by three inches? Or shorter shifter in hieght?
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
