help! car wont start
Old Sep 13, 2006 | 02:41 PM
namelesspenguin's Avatar
chasing those red numbers
the other day i was parking and i accidentally stalled. i didnt really think much of it cuz nothing has ever happened before. anyway, on my way out i go to turn on the car and nothing. try it again, it hesitates then turns on. since it turned on, i didnt think anything was wrong. later that day i go to leave and my car wont start. i tried many times and nothing. so, i think i burned out the starter fuse because when i turn the ignition all i can hear is an almost inaudible eeeeeeeeeeeeeeeee. the car deosnt even try to turnover.
does anyone know where the starter fuse is?
can it be anything else?
p.s. 88 na se
Old Sep 13, 2006 | 05:06 PM
bump
Old Sep 13, 2006 | 05:58 PM
kungfuroy's Avatar
Chicken Adobo
First check out all your battery cables, make sure they are connected tight with no corrosion
When you turn the key tothe Start position, do you hear a click or is that 'eeeeee' sound you describe more like something spinning?
Old Sep 13, 2006 | 06:04 PM
rockman7's Avatar
your stater cut relay is right next to the clutch master cylinder.. It should be clicking(its a faint sound). Next do like the other guy said check the cables, also check batt voltage, should be 12.6, if not charge it, when all else fails the starter brushes inside the motor/soloniod are sticking. You need to take a hammer down to the starter through the engine bay and smack it a few times... Its an old school trick.. I just had the same problem with mine.
Old Sep 13, 2006 | 08:47 PM
prjct87rx7's Avatar
REST IN PEACE DAVE!!!!!!
it was probably just flooded to begin with?
Old Sep 13, 2006 | 09:22 PM
ericgrau's Avatar
Clean.
A push start is always worth trying... unless it'll end up in a bad place if it doesn't start.
Old Sep 14, 2006 | 01:59 AM
i dont hear a clicking, and the "eeeee" sounds more like its coming from a relay more than sumthing spinning.
ive been push starting it for the last couple of days. only to and from work.
Old Sep 14, 2006 | 02:19 PM
rockman7's Avatar
eh man just raplace the starter already, did you try any of the directions, what spinning?? the engine rotating but won't start? or it rotates but won't "spark"?
Old Sep 14, 2006 | 02:20 PM
rockman7's Avatar
eh man just replace the starter already, did you try any of the directions, what spinning?? the engine rotating but won't start? or it rotates but won't "spark"?
Old Sep 14, 2006 | 02:31 PM
hehe
well i checked all the fuses and lines, and they all seem to be alright
so maybe it is the starter
ill let u kno when i replace it later on today
Old Sep 14, 2006 | 04:53 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
get a volt meter and start the car. if the volt drops below 9.6, then its the starter. If the voltage doesnt even drop at all, check all the connections from the battery to the starter.
Old Sep 15, 2006 | 03:39 AM
rockman7's Avatar
you put the starter on yet ??
Old Sep 19, 2006 | 04:48 PM
Talking
oh yea, it was the starter!
who wouldve known, stalling wouldve killled your starter
but then again, it was the stock 88 starter.
CASE CLOSED
thanx guys
Old Sep 19, 2006 | 07:44 PM
asiansuperstar's Avatar
Does stalling the car do any damage to the engine? Because i've recently stalled ALOT.
gtcd
30
Aug 19, 2015 02:44 AM
torky007
Aug 17, 2015 05:14 PM
ashleymiche
Aug 14, 2015 12:59 PM
