How to properly fix tail lights?
Old Sep 13, 2006 | 01:07 PM
dj55b's Avatar
Alright, I'm pretty sure that alot of you guys have this problem since almost everycar that I see here has this problem. The outside lens of the tail lights start coming off from the bottom corner closest to the center black piece and allowing dirt and water to seep through. If anyone knows the best way, to safely fully remove the lens and then what adhesive to use to re-assemble the parts would be great. Thanks
Old Sep 13, 2006 | 01:51 PM
Rogue_Wulff's Avatar
Too old to act my age
Clear or black silicone, the adhesive type. It's best to allow it to fully cure before attempting to reinstall the lights into the car.
Old Sep 13, 2006 | 02:16 PM
dj55b's Avatar
whats the best way of taking them off without breaking them since that part is covered?
Old Sep 13, 2006 | 02:25 PM
Luck plays a huge role in getting them apart without cracking them. Care and pateince help, but you still need luck on your side.
Old Sep 13, 2006 | 02:34 PM
trochoid's Avatar
Old Fart Young at Heart
Heat gun/hair dyer to soften the adhesive, then work very slowly. I have read of members putting them in the oven first, but I would be very careful going that route.
Old Sep 13, 2006 | 04:04 PM
I used a heat gun and slowly worked my way around the lens seperating it..The key is patience, but it should only take 20 min per light tops to get it totally apart..Once you get it apart, clean it thoroughly, and remove as much as the stock sealer/adhesive as you can. When you are done, use some BLACK silicone to seal it back together..Even if they were as messed up as mine, they will look great when you are done..You can see how bad mine were when I got it apart, they now look like new..
If you do not have a heat gun, try the oven..Place a damp towel on a cookie sheet and face the light with lens down on top of it, let it in the oven at 325 for 15-20 min and take it out and seperate lens..Make sure to remove all bulbs, ect. before you place in oven though..Good luck and I hope theese pics help, I just did mine 2 weeks ago and they look like brand new..
Old Sep 13, 2006 | 09:32 PM
FirebirdSlayer666's Avatar
Famous Taillights
If it's already coming apart it shouldn't take much to pull it the rest of the way. Just be careful and it'll come loose. I used seal all to put mine back together. It seals great and dries fast
Old Sep 14, 2006 | 07:54 AM
dj55b's Avatar
Hwy guys ... thanks for all the advice ... I have a heat gun .. I just need to buy silicone now. I should be takling this project this weekend or maybe tonight if I have time. Thanks.
Old Sep 14, 2006 | 08:27 AM
dj55b's Avatar
I think that this should be in the archives ... just a thought though ... lots of good pics on the process here .
Old Sep 14, 2006 | 04:29 PM
zlyricist's Avatar
are people having the same problem with sa tails?
Old Sep 14, 2006 | 04:46 PM
dj55b's Avatar
not sure ... but i just did mine right now ... total project time 1 hour ... includes going to the store buying clear silicone ( I was going to use the balck one but then i saw that the stock stuff was clear so i decided to go that route.) They look alot better now. Heat gun does definatly help ... word of advise try not to point it too long in one spot though ... get rather sticky after a while. I've got some pics of the process which I'll add in a bit.
Old Sep 14, 2006 | 09:10 PM
slayerx7's Avatar
The nonspatial continuum
How dark of tinting would you go? I have some 5% vlt tint, but I dont know how well my brake lights would show up, which could be potentially dangerous. What do most people use 20%?
Old Sep 15, 2006 | 01:48 AM
The SA tail lights do not have the covers on them. They are just a simple lens, screwed onto the base. They get dirt in them, 15 minutes invested in removing 6 or 8 screws per side, and clean the lens and reflectors, reassemble. Problem solved.
Old Sep 15, 2006 | 10:45 AM
dj55b's Avatar
Hey here's another question ... how could you make the outside look good ... it looks like its got small surface scratches and stuff on the outside that make it look not as clean as new ... is it possible to be sanding it with like 1,000 grit or maybe even higher sandpaper (wet sand obviously) to make it look better? Or maybe just simply taking a buffer with a buffing compound to clean it up?
Old Sep 15, 2006 | 11:31 AM
trochoid's Avatar
Yes, wet sanding and polishing will work. If the scratches aren't deep, they can be polished out. Start with an automotive metal polishing compound. It that doesn't take it out, then wet/dry paper. I usually start fine, then use a coarser media if needed. By the time you get to 2000 grit, you cat begin the polishing steps.
There are compounds out there to remove the yellowing from headlight covers/lenses. Try that too.
Old Sep 16, 2006 | 09:51 AM
dj55b's Avatar
Its not really yellowing ... it mostly list scarthces that are making it appear dull .. i've tried detailing claiy but that did nothing i thought it would be able to clean things up a little ... I will try to do the sanding tomorrow or monday ... should I be sanding them horizontally or vertically ? Also Metal polisher? LIke mothers rim polisher? or something like that?
Old Sep 16, 2006 | 09:53 AM
kgray's Avatar
GOT WANKEL?
try rubbing compount or polishing compuond. it will be the best of both worlds. that mothers stuff does wonders on polished aluminum and chrome, but is more of a wax then anything.
Old Sep 16, 2006 | 10:25 AM
trochoid's Avatar
The compounds that take the yellowing off of headlights are a heavier cut than Mothers, which is a finish polish. There are many different compounds and 'cuts'. Finishing clay is a final step, too fine to do any aggressive cutting.
