R85
Old Sep 9, 2006 | 12:54 AM
BLitzed33's Avatar
R85
Made a final pull, maxed out the compressor and ran out of turbo...27 lbs boost
561 whp
445 lb ft torque
spiked to 31 lbs,but kept bleeding down to 27-28 lbs but couldnt keep flowing the volume at high rpm's with a 22 lbs waste gate spring and boost controller set to max and even with a manual one on there as well. Compressor side is only like a 61mm.
Old Sep 9, 2006 | 12:56 AM
IRPerformance's Avatar
Sponsor
Nice that someone isn't afraid to try some real boost on a single
Old Sep 9, 2006 | 01:04 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
nice #'s
Old Sep 9, 2006 | 08:36 AM
mr2foryou's Avatar
600+rwhp club member
Awesome numbers Greg. Hopefully in about 2-3 weeks, we'll see what my 40R can do at those levels. What boost controller are you running?
Dee
Old Slow Coach's Avatar
Front Range Express
I'm impressed!!! NIce numbers!!! Got a couple questions, if you don't mind... What was your RPM where the torque curve starts to flatten out? What was your max RPM? Is that a ball bearing turbo? EGTs?
Old Sep 9, 2006 | 08:46 AM
BLitzed33's Avatar
Thanks Dee, yours should make good numbers once everything is done. I am running a Greddy Type S (basically the old profec B with 3 *****).
III Gen X:
rpms peak and flatten around 4400 rpms which is where it makes full 27lbs boost, so I see 27 lbs at around 4400-4500. We pulled to 8500 rpms. It is a NON Ball bearing turbo. EGT's peaked around 1390-1400 degrees F. with probes tapped in each runner before manifold...they were very even from front to rear rotor housing with that Xcessive Lower intake manny. Thanks for the compliments
Old Sep 9, 2006 | 09:03 AM
Great #s .
Good news on the GZ LIM, I ordered one the other day
Old Sep 9, 2006 | 09:09 AM
BLitzed33's Avatar
Originally Posted by GoodfellaFD3S
Great #s .
thanks Rich. You will like it, are you going to do the 4 top feed setup that is an option, or just cap the other bosses off and run traditional top and side feed setup?
Old Sep 9, 2006 | 09:36 AM
mr2foryou's Avatar
That's what I wanted to hear. That's what I have also.
Dee
Old Sep 9, 2006 | 10:05 AM
Front Range Express
Impressive! Looks like you have a great build and tune!
Old Sep 9, 2006 | 10:53 AM
turbodrx7's Avatar
PURIST
Nice numbers, glad to see you managed to squeeze some more power out of that turbo.
-Austin
Old Sep 9, 2006 | 12:51 PM
BLitzed33's Avatar
Thanks Austin and Gen X, maybe a bigger turbo is in store, haha
Old Sep 9, 2006 | 02:06 PM
mr2foryou's Avatar
Sweet, do I see a 42R in your future?
Old Sep 9, 2006 | 04:28 PM
BLitzed33's Avatar
Have to keep you guessing
Old Sep 9, 2006 | 05:42 PM
mono4lamar's Avatar
In the burnout box...
great numbers greg... i'll get my r85 tuned once i get my god damn clutch from import proformance!!! GRRRR
Old Sep 9, 2006 | 06:19 PM
BLitzed33's Avatar
Def. keep me posted on that, what clutch are you going with?
Old Sep 9, 2006 | 08:16 PM
mr2foryou's Avatar
I bet you'll probably go with the 42, 45, or 47? A GT47 would be awesome, but you'll have to get a new manifold made for it and it would probably not fit under the hood. But you could just cut a hole in it. That's what I would do anyway. I think you should pm me with what you are thinking. I won't tell.
Dee
Old Sep 19, 2006 | 05:29 PM
mr2foryou's Avatar
Greg, when are you gonna go to the track man? I am ready to see/hear what your car can run.
Dee
Old Sep 19, 2006 | 05:45 PM
BLitzed33's Avatar
Dee
Pretty soon, probably in Oct sometime.
Old Sep 20, 2006 | 07:22 PM
mono4lamar's Avatar
greg im running the new act zx3-hdr6 im the experiment haha. i've got soooo much **** to do and still need to talk to ray wilson. everyday i call he just steps out for this or that! not my luck i'll keep yah posted my r85 brotha!!!
Old Sep 20, 2006 | 09:42 PM
AZ'sFastFD3S's Avatar
What kind or rear-end you running. Better get a good one, I know .
Old Sep 20, 2006 | 10:29 PM
BLitzed33's Avatar
I am running a KAZZ LSD, 4.33 gears, Chromoly Axles.
Old Sep 20, 2006 | 10:30 PM
BLitzed33's Avatar
Thats cool, whats left to be done? Keep trying or leave a message with Sam, he will get back with you.
Old Sep 21, 2006 | 08:54 PM
mono4lamar's Avatar
i talk to sam daily... he says everyday that ray will call me back. im not mad i know they do amazing work and **** happens or you forget. lol one of these days i'll get him back on the phone with me. i talk to sam more than ray and its not even anything informative. whats left to be done haha... if i could only tell you. theres a lot but if i get the answers i need i might be able to bust most of it out this weekend. i'll take some pictures tomorrow night or saturday
Old Sep 21, 2006 | 09:11 PM
ErnieT's Avatar
Living life 9 seconds at a time
Greg,
You can buy my GT42R
The 45R is coming! lol...My tranny and engine parts came in today so next week is possible @ Englishtown. You down??
