Need Help! Two problems!
Old Sep 7, 2006 | 01:02 AM
rexhvn's Avatar
Rotary for life!
I have a 93 FD, everything is stock unless a 2inch exhaust all the way through... my problems are:
1 - It struggles to get into 1st gear while your rolling... it slips right in when your at a complete stop.
2 - My FD blow white smoke when its cold. When it heats up, the while smokes stops...
What's causing it? What do I need to do to prevent this?
Any help is appreciated! Thank you!
Old Sep 7, 2006 | 02:55 AM
NeedFD's Avatar
R. R. R.
#1 is called manual transmission.. it's not supposed to go into 1st gear when the car's rolling... period..
#2 white smoke.. it's called condensation, if you wanna fix it, warm the car up..
Is this your first time driving? Those sound like regular symptoms on any car
Old Sep 7, 2006 | 03:17 AM
spandy's Avatar
Patience
The tranny doesn't like to engage usually at anything over 5mph if you are trying to drop into 1st gear, so don't force it. Either try to rev match, or just don't do it. 1st is just to get the car rolling or for a snap neck take off, 2nd gear is fine once the car is in motion.
Or just slam on your brakes, come to a stop and get it into first and take off like a bat out of hell
Old Sep 7, 2006 | 10:21 AM
White94RX's Avatar
BMW Tech
+1, normal for trans, not supposed to hit first unless stopped.
Yeah, sounds like condensation in exhaust, this is normal. Worst case scenario is a little coolant leaking into rotor housing and burning off when you crank it. But since you said only happens when cold, this doesn't sound like your problem.
Old Sep 7, 2006 | 10:24 AM
charlies7's Avatar
3rd rotors a charm
this is off topic but an 2in exhaust is smaller than stock...i hope you mean 3?
Old Sep 8, 2006 | 12:42 AM
rexhvn's Avatar
Rotary for life!
Yeah I did lol.. its a 3inch, sorry...
Old Sep 8, 2006 | 01:29 AM
prescription 7's Avatar
RX7club addict
all normal
Old Sep 8, 2006 | 04:33 PM
existanzrx7's Avatar
Just Boosting
It sounds like its his first stick shift car at that his first car. That’s all normal
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
