seal failure? im a complete newb!
Old Sep 5, 2006 | 12:48 PM
jdmjoe's Avatar
hi i am a complete newb to the rx7's never worked on one and never really got to drive on to be honest....
i am in the market for a new car and like with any car you have rumors as to what goes bad on the car....
i have always loved the FD body style, and the interiors. and really appriciated the small displacement and alot of power these cars could produce.
but anyways i alwyas here about the engines "seals" going bad and the motor is very unreliable and tempermental...so if anyone could tell me about problems with "seals" or any other prblems common with the car please tell me! thank you ahead of time for your time!
joe
Old Sep 5, 2006 | 01:05 PM
adrock3217's Avatar
Boost in..Apex seals out.
The rotary engine is reliable, if the owner is reliable. If you do periodic maintainence (oil change every 2.5-3k miles, coolant flush every 6months, etc), it will be just as reliable as any other engine. The engines fail when the OWNER fails -- to complete a task. They are not keen to being mal-maintained.
The "seals" you hear of are most likely the apex seals. www.hotstuffworks.com has a nice little article on How Rotary Engine's Work.
Search! :-O
Old Sep 5, 2006 | 01:16 PM
cewrx7r1's Avatar
Eye In The Sky
Seal failure is normally a result of overheating caused by the undersize stock radiator, and the stock overheat thermoswitch having too high a setting.
These are corrected by what is called reliability mods:
(1) bigger all aluminum rad
(2) FC thermoswitch with 207F set point
(3) fan mod switch (manual way to turn fans on)
(4) PFC with fan temp points set lower (86C, 86C, 88C)
(5) non stock DP with thermo wrap and ceramic coated
(6) bigger IC
Old Sep 5, 2006 | 01:33 PM
rynberg's Avatar
Welcome to the forum. Please use the FAQ thread and search function before posting general questions.
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
13
Jan 9, 2018 11:19 AM
yetter227
20
Sep 5, 2015 11:57 PM
