WOT at start...help
Old Sep 4, 2006 | 12:16 PM
DassRotary2427's Avatar
WOT at start...help
ok i took the throttle body off to change plug wires and now i have a problem. when i start the car it revs to wide open throttle. and then i have to shut the car off. checked everything twice to make sure everything was put back. any ideas? and one more thing is that now the RPM needle with the car off rests on the opposite side of the guage at like 9000RPM
Old Sep 4, 2006 | 12:27 PM
Stanello's Avatar
backslash beanbagrace
Maybe you snagged the throttle or cruise control cable in the process? Maybe there is a huge vac leak now?
As for the tach... I dunno. I've never seen that happen.
mad_7tist's Avatar
sounds like the linkage is caught for the throttle. do the throttle plates come back to rest at ful close? check free travel of the cable.
as for the tach... idk problem with the cluster
Old Sep 4, 2006 | 12:40 PM
Rocking Rotary's Avatar
there could also be a large air leak after the throttle body
Old Sep 4, 2006 | 02:41 PM
ill check but as for the tach problem it just happened. never did it before. so it has to be associated with the problem i think?
Old Sep 4, 2006 | 03:57 PM
you think if the TPS was bad it would effect the tacometer
matty
47
Oct 4, 2015 02:45 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
sip
19
Sep 7, 2015 03:33 PM
R7rexy
19
Sep 2, 2015 10:24 AM
Craze8
11
Aug 14, 2015 06:11 PM
