Haltech FYI RPM Spikes
Old Sep 3, 2006 | 01:01 AM
Sesshoumaru's Avatar
Tenseiga
FYI RPM Spikes
Just a fyi for some of you guys running a CAS.
I had trigger spikes and my wiring was good/pick up on cas good/power cables etc..
Still had a few spikes.......... couldn't solve it...
Got to looking- and the stock wiring switched colors at the connectors.
Red becomes white... etc......... So when you are wiring up the CAS and using the stock connector DO NOT go off the colors of wires there.
Use the color of wires directly off the CAS (about 3 inches long)
Swapped the wires and works perfectly (Gain 0 filter 2)
I guess I just assmed they would switch colors......
Old Sep 4, 2006 | 02:36 PM
Wankel7's Avatar
Haven't we ALL heard this
Stock wiring... you talking stock haltech wiring?
Old Sep 4, 2006 | 05:38 PM
Tenseiga
no the cas has a connector on it.
The connector plugs into a stock shielded wire.
If you cut the shielded wire after the connector the colors are switched from the CAS colors.
You will most likely used a bit of stock wires unless you hard wire your CAS or put in your own connector.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
musker
Oct 1, 2015 05:58 PM
