Megasquirt how to tell primaries from secondaries...
Old Aug 31, 2006 | 11:43 PM
flaresniper's Avatar
when i took off my injectors, i fuxed up and didnt mark which ones were primareis and secondaries (the injector clips).
help.
Old Aug 31, 2006 | 11:47 PM
papiogxl's Avatar
What's the point??
disconnect the DB-37 connector at the MS, then test either pin 32 or 33, they should have continuity with the one of the leads on the primary injectors. (use ohms, when there are 0 ohms, there is continuity.)
edit:http://www.megasquirt.info/ms2/v3ext_wiring.gif
32/33 are the cyan leads on the bottom right
You can do the same thing for leads 34/35 and these are the secondary injectors
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
eplusz
15
Oct 7, 2015 04:04 PM
Jmolina0163
Oct 3, 2015 10:04 AM
