oil catch can
Old Feb 25, 2002 | 05:49 PM
busy13b's Avatar
Om Namah Shivaya
oil catch can
Looking for tips on installing an oil catch can.
I'm guessing one line goes from the oil fill neck to the catch can. Do we need another line that feeds to the can? Should the can be sealed or would it be better to have a filter on it, to allow for breathing?
What can be removed from the emmission system when installing a catch can?
Does anyone have pics of a catch can installed in their N/A or TII??
Regards,
Shawn
Old Feb 25, 2002 | 05:59 PM
NZConvertible's Avatar
I'm a boost creep...
There'e very little reason to install one on a rotary because there's not much to "catch". The "crankcase" (Mazda's terminology, not mine) ventilation line to the intake is tiny for that reason. There is no crankcase and no blow-by to pressurise it like in a piston engine. The factory system, which ventilates the chamber containing the oil, should be perfectly adequate.
Old Feb 25, 2002 | 06:26 PM
Turblown's Avatar
Turn up the boost
ah, thxs for the info i was about to buy one
Rotary Performance Parts
Old Feb 26, 2002 | 07:57 AM
busy13b's Avatar
Om Namah Shivaya
What about when removing the PCV? Should the nipple on the oil fill neck simply be plugged up?
Old Feb 26, 2002 | 10:43 AM
95R2-89TII Ground Zero's Avatar
Banned
I have heard that same thing from a number of people.
whinin
Mar 30, 2019 07:53 PM
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
sherff
Sep 12, 2015 12:22 PM
tiger18
Sep 3, 2015 08:27 PM
