10-8-10-7 boost???
Old Feb 25, 2002 | 04:25 PM
MattRX7's Avatar
10-8-10-7 boost???
I'm currently getting a 10-8-10-7 boost pattern.
After 4500 rpms, I drop to 8 and quickly go back up to 10 like I am supposed to. However, the boost immediately drops to about 7 after that (probably by about 5000 or 5500 rpms). My only mod is a dp.
Anyone else have this problem before? I'm hoping someone can narrow it down for me before I go checking the whole system.
Thanks,
Matt
Old Feb 25, 2002 | 04:54 PM
DamonB's Avatar
Check the classic culprits: crossover tube from y-pipe and it's couplers. Sounds like you're a likely candidate.
Old Feb 25, 2002 | 05:57 PM
pp13bnos's Avatar
Pineapple Racer
My car always did that from day one. I think its suppose to infact. With all the mods i have on my car, my boost pattern is still a 10-9-10-9. It seem like the efini y pipe brought it up 1psi or so at redline. CJ
Old Mar 24, 2002 | 02:52 PM
I got a same problem.
and my car not getting full boost(7PSI) before car warms up is it normal I think it's double throttle but not sure.
someone help!!
Old Mar 24, 2002 | 03:48 PM
Enthu's Avatar
Still has an RX7.
HOw much is the efini Y-pipe? and where should I get one at>?
Old Mar 24, 2002 | 04:04 PM
Indo Audio's Avatar
It could be some check valves, the valves may not be holding enough pressure or vacuum to keep the actuators open/shut for long enough.
Old Mar 24, 2002 | 05:11 PM
maxpesce's Avatar
Ex fd *****
Factory spec says after transition you should see steady 10 psi boost untill at least 6500rpm and then it may drop to 8-9psi at 8000rpm (redline) stock.
Old Mar 24, 2002 | 07:43 PM
rynberg's Avatar
sounds like your main cat could be clogged as well
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
