Stock Sucks!
well I dynoed today, and all i cna say is DAM i hate stock carbs. 99.6 on the ground from my 12a street port.I cant wait till my rebuild kits come 4 the webers. now the bad part. i did put down more than a friends 90 vert 79 hp on the 2nd run... dam thats just wrong
nope no wide band o2 ...whats the point with stock B.S. and im running a stock pump. I do have a upgrade pump, reg, and carbs but figure ill put it all on at 1 time
Nikki-Modder Rex-Rodder
You guys sound like a buncha spoiled brats!
What the hell'ja want; a full out racecar for nothing?
And gueeze, whad'ja expect from a stocker carb on a street port?
It's the title of this thread that kills me! Stock does'nt suck, dude. It's already "one-up" on almost any other stock comparable car.
It's just a great starting point, that's all.
What's all this Dyno-**** about, anyhow? I keep reading about how they are'nt consistant with one and other...
You know that guy that caught the gazillion pound marlin in Florida over the summer? The scale they had was'nt big enough, so they had to drive the thing to some farmer (or something) that called up and said he had a certified scale that was big enough.
Point?...The scale had to have been certified by the "Weights and Measures" dudes for it to have been official.
Don't dynos get certified by these guys, too?
Trending Topics
Hey, my car was a street port with a stock carb
Come to think of it 100whp is about right... I calculated 130 or 138hp at the flywheel, depending on whose numbers you go by, and that was with a better (but still insufficient) fuel pump.
A stock carb is good for about 145-150hp, on a stock port engine, after you play with the fuel curve
The power can be had, you just need to TUNE it.
Come to think of it 100whp is about right... I calculated 130 or 138hp at the flywheel, depending on whose numbers you go by, and that was with a better (but still insufficient) fuel pump.A stock carb is good for about 145-150hp, on a stock port engine, after you play with the fuel curve
i was thinking(hoping) id have about 115 or so on the ground. the main reason i did dyno it was for a baseline. when i get this r.e dcd setup on and tuned i want to know what was and what is
streetlegal?
Mar 17, 2022 02:46 PM
rx8volks
Canadian Forum
Aug 20, 2015 10:24 PM
