RX7 Blind Spots?
Old Aug 1, 2006 | 03:20 AM
Kentetsu's Avatar
Angry RX7 Blind Spots?
Has this ever happened to anyone else? I'm 6 feet tall with a 34" inseam, so I'm kind of a tight fit in my car to begin with. I find that the rear view mirror is located in a fairly bad position, and creates a blind spot under some circumstances. I haven't been in an accident for over twenty years and consider myself to be a very safe and attentive driver. However, this morning I totally deserved to get T-boned in a very big way. As I was pulling out of the plant parking lot this morning (making a left turn into the road), I looked both ways and saw nothing but completely deserted road in both directions. However, after I pulled out into the road I saw (in my rear view mirror) a white blazer pull into the lot and there was a big box truck right behind him. I must have really scared the crap out of the driver of the blazer as I turned left into the road right as he was (I assume) turning into the parking lot. The box truck had been behind the blazer, waiting for him to turn in. Both of these vehicles had been totally obscurred by my rear view mirror when I checked the road before pulling out. My guardian angel probably had a nervous breakdown! Has anybody else ever had a problem with this? I'm tempted now to just remove the damn thing, but I use it constantly and would feel naked without it. I am open to suggestions at this point in the game...
Old Aug 1, 2006 | 03:30 AM
Rogue_Wulff's Avatar
Too old to act my age
Being damn near the same build (5'11", 34" inseam), I totally understand the dilemma. The inside mirror is mounted a little too low, for me. It blocks the view out the front, and leaves a lot to be desired for the view to the rear. It's too low to see the front, and too high to see out the rear..........
It is also too damn valuable to not have.......
Sometimes, I worry it ruin my record of over 25 years on the road, and never having an accident, other than getting sideswiped at a red light, in a semi. Ruled as a "Non-Preventable". Less than 5% of accidents are ruled non-preventable in the trucking industry.......
Old Aug 1, 2006 | 03:38 AM
speed7's Avatar
I'm 5'11" and I dont' have this issue.. I've found the blind spots on the first gen are very small. I've never really driven a 2nd so I can't comment on that generation. However the 3rd gen has huge blind spots. IDK.. maybe you two should change how you sit in the car.
Old Aug 1, 2006 | 03:51 AM
The inside rearview mirror is a blind spot on many vehicles. The number of people that hang things from the mirror, is always a little concerning. They can't see around that crap worth a ****.
Changing how I sit, will not solve the issue. I already sit as low as possible, due to having a sunroof model.
Is it just me, or does the throttle pedal seem to be a little too close to the seat, compared to the clutch pedal, depressed? Put the seat at a comfortable spot for the throttle, and you cannot fully depress the clutch.........
Oh well, I aint gonna give up my car for anything, except snow. I use the truck for snow.
Old Aug 1, 2006 | 04:02 AM
DriftFB's Avatar
Reno Rotary.
I am 6'2 and have never had my inseam measured, but I find that any blind spot the Rx has is easily viewed by turning your head, just what your supposed to do. My only close call was once when I was backing out of my driveway there was a pedestrian walking and the wierd C-pillar blocked most of their body.
I also have no accidents except for one where the lady stepped out of the car, looked at me and said, "its 100% my fault."
Old Aug 1, 2006 | 04:35 AM
Kentetsu's Avatar
Turn my head? I never thought of that! I'll have to try that right away... Hmm, did you even read my post? Turning of the head will not cure this issue. You would have to duck your head way down, or lean way over to the side, in order to see under or around the mirror. Thanks for your input though... Okay, so I'm a little grumpy this morning!
Old Aug 1, 2006 | 05:55 AM
84RX_Se7en's Avatar
Rockin' the suburbs!
There are a lot of blind spots. Chiming in at 6'3" I'm crammed in my car. I can't stand passengers because that side is then one giant blind spot. Especially if they are bigger or have a huge head.
Two cars can fit into the adjacent rear blind spots.
Old Aug 1, 2006 | 06:06 AM
OneRotor's Avatar
RAWR
i'm almost 6'5, have a 34 inch inseam, and weigh between 180 and 185 pounds on any given day. I don't have a sunroof, and my head sits on the roof. I have a pair of cheapie buckets that need to be replaced, but they make it so I can drive my 7. The blindspot with the mirror was one of the first things that I noticed when I first bought my 7 last summer. Unfortunately, I have this problem with every car that we own except the fullsize van.
Old Aug 1, 2006 | 11:03 AM
bliffle's Avatar
I'm 6'2". On every 7 I saw the post off near the domelight and mount a glueon mirror from the autostore down near the dashboard. Works fine. Sure clears up the forward view!
It's the rear quarter blindspots that give me fits.
I've never caused an accident in 50 years, and have only been hit when standing still. I drive defensively, but not necessarily slowly.
Old Aug 1, 2006 | 11:37 AM
teamzzyzx's Avatar
Can't Have One.
I had the same problem with blind spots, and hated "rubber neckin" just to check behind me all the time.
Problem Solved: $20 @ Pepboys for a Wink Mirror. . . .Old School
Old Aug 1, 2006 | 11:47 AM
Jozay721's Avatar
'Nothing like a rotary'
well im 5'5 and my blind spot in the fb is only when turning left or looking left on the highway. its the trim piece in betwen the drivers window and the small window in back, what i do to avoid blind spots when going left is stick my head out of the window but in ur case kenetsu i think u might just be too tall, ive noticed that if i sit down wrong in my car i cant see crap out the rear view mirror, but once i get comfy i see perfect
Old Aug 1, 2006 | 12:50 PM
Manntis's Avatar
add to cart
6'2" - never really had a visibility problem except when merging onto a freeway at a shallow angle with traffic to my left - the thick B pillar only causes problems for me then. All else is solved by shoulder checking.
Old Aug 1, 2006 | 01:03 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
Thats my big problem in all my cars, but it was big big in the FB.
Old Aug 1, 2006 | 01:11 PM
64mgb's Avatar
Go Hawks!
I think many people are missing Kentetsu's point. I think he's having trouble seeing things in line with the rear view mirror. Like at a stop sign with a car from the right. I've had this same problem and it's a little embarrassing (not to mention unnerving) when I don't see any cars there and start to go, only to find a car sitting there, because I consider myself to be a good driver.
Rich
Old Aug 1, 2006 | 01:19 PM
Play Well
Oh I misread. The only time I really had trouble with the mirror is if the the car at an intersection was at a slight incline and I am at the base, but that isnt somethign common in most areas.
Old Aug 1, 2006 | 01:26 PM
DriftFB's Avatar
Reno Rotary.
I miss-read, and I think I might still be. So your not talking about the blindspots behind you but the spots in front where you can't look through the mirror(s)?
The only time I have had a problem with this is when I am trying to see a traffic light sometimes.
Old Aug 1, 2006 | 01:58 PM
Rx-7Doctor's Avatar
Well, I solved the problem when i had one of my Fb's by putting in Recaro seats that sat much lower to the floorboard. The problem is when you are tall the mirror acts like a shield that does just enough blocking to cause a problem.
Old Aug 1, 2006 | 02:35 PM
notveryhappyjack's Avatar
1 bar boost
my four point sparco's create huge blindspots on the passenger side, I have almost gotten myself in trouble a few times for not being able to lean forward and give a good check. now I just take more time when doing right lane changes.
Old Aug 1, 2006 | 02:39 PM
1 bar boost
are you saying that the mirror was in the way looking through the windsheild ? in your forward field of view ? I think I read your post incorrect
Old Aug 1, 2006 | 03:25 PM
Rx-7Doctor's Avatar
Yep, that is what he's saying. I recommend removing the stock mirror. Getting a universal mirror that adheres to the glass and positioning it so it gives you the best field of view.
Old Aug 1, 2006 | 10:04 PM
rOtAryIsbEttEr's Avatar
voo doo witchdoctor
im 6-3, maybe taller if i'd sit up strait, i had the same problem after i superglued my mirror back where it was supposed to go after i bought my fb. it was a problem for a few days until i realized i could peer my eyes out the sunroof and see everything around me.
Old Aug 1, 2006 | 11:16 PM
Rx-7Doctor's Avatar
Old Aug 2, 2006 | 09:41 AM
Kentetsu's Avatar
Yeah, that's exactly it. Picture coming to a four-way stop and not being able to see the car to your left. A very embarrasing experience for someone who considers themselves to be an excellent driver.
(sorry for the sarcasm earlier)
Old Aug 2, 2006 | 10:16 AM
64mgb's Avatar
Go Hawks!
Don't you mean "Picture coming to a four-way stop and not being able to see the car to your RIGHT"?
Rich
Old Aug 2, 2006 | 10:26 AM
nnkie's Avatar
im 5'4" no problems here !!!! Car sits like it was made for me.
