why won't my motor work?
Old Feb 22, 2002 | 06:33 PM
adssoccer's Avatar
i have a 1984 gsl-se. i recently replaced the fuel filter and had the fuel injectors rebuilt. after connecting the hoses and putting the intake all back together i started it up. after chugging to a start, the rpms go to 3000 for a second or two and then slowly drop down to zero. if i keep my foot on the gas and keep it at or above 3000, everything sounds fine and it seems to work, but anywhere below 3000 and it dies. im new to rotaries and im pretty frustrated. what should i check? what might be the problem?
Old Feb 22, 2002 | 06:42 PM
Felix Wankel's Avatar
Super Newbie
You more than likely have a vacuum leak somewhere.
Old Feb 22, 2002 | 06:43 PM
hanman's Avatar
Ditto
hanman
Old Feb 22, 2002 | 06:44 PM
adssoccer's Avatar
should i just replace all the hoses? they are 17 years old
Old Feb 22, 2002 | 06:46 PM
Super Newbie
How far apart did you take the car?
Old Feb 22, 2002 | 06:48 PM
adssoccer's Avatar
i took the dynamic chamber and upper intake manifold off so i could get to the injectors
Old Feb 22, 2002 | 06:50 PM
Super Newbie
Did you replace the intake gaskets?
Old Feb 22, 2002 | 06:51 PM
adssoccer's Avatar
yes, but do they need sealant?
Old Feb 22, 2002 | 06:54 PM
Super Newbie
They shouldnt. I assume you cleaned the mating surfaces well? I'd just look around for a broken or disconnected vacuum line. Replacing them all would never hurt
Old Feb 22, 2002 | 06:55 PM
adssoccer's Avatar
ok, thanks!
Old Feb 22, 2002 | 07:32 PM
hanman's Avatar
you can use starting fluid, wd40, or even propane to find the leak, just be careful. And keep a fire extiguisher handy.
hanman
Old Feb 25, 2002 | 06:25 PM
adssoccer's Avatar
im in the process of replacing the hoses and cleaning the surfaces for the gasket between the upper and lower intake manifolds. how would you suggest i get rid of the little bits of old gasket still stuck to it?
also, i didnt mention the high pitched whining or screaming it makes sometimes. i added oil and it worked fine for a good 10 minutes or so, but then it started up. i shut it down as soon as i hear it because its so loud im thinking its something serious. what could that be?
Old Feb 25, 2002 | 07:13 PM
Super Newbie
Check the fan clutch.
Old Feb 25, 2002 | 09:44 PM
adssoccer's Avatar
would taking the intake off have affected the fan clutch?
Old Feb 25, 2002 | 09:49 PM
Super Newbie
No. But I can't think of much else that will squeal...
Old Feb 25, 2002 | 09:56 PM
adssoccer's Avatar
it wouldnt have anything to do with the apex seals would it. i sure hope not.
cristoDathird
28
May 30, 2019 08:47 PM
alphawolff
Nov 17, 2015 05:57 PM
andyvideopro
Aug 11, 2015 09:16 PM
