Modifing Stock Rotors---high Compression
I Think This Idea Will Work.. Rotors Are Made Of Iron Stell I Believe. Why Not Take 1/8 In Plates And Weld Them In To Rotor Grove.
It Will Make Them Slight Heavier But Hp Gain Will Be Much Greater..
Im Sure It Will Be Possible To Get 13:1 Ratio, Thats Close To 30-40 Hp Gain..
I've always wondered about something like that. But the increase in power you project is a little optimistic. On a piston engine you get 3-4% increase for every point increase in compression(just an old rule of thumb don't ask for dyno sheets) If it worked it would probably be in the 12-15hp range. If you are fighting for every HP fitting in a rule structure it would be worth a try.
Originally Posted by rx7vadim
4% Is 6 Hp,, Then 4 Point Increase 9.4:1 To 13.4:1 =24hp
Trending Topics
Originally Posted by samperry007
I would like to read up on this. On what forum was it, if you remember?
msilvia
28
Apr 14, 2016 12:58 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
JIMMY54
Aug 12, 2015 05:40 PM
