13b RPMs
Old Jul 27, 2006 | 01:30 PM
C Rock999's Avatar
13b RPMs
Hey guys,
I have a single turbo PP 13B motor. It is properly tuned, and i believe it is tuned on the safe side. I am wondering what are the highest RPMs I can take the motor.
Thanks,
Chris
Old Jul 27, 2006 | 01:34 PM
drago86's Avatar
That depends on what internal modifications were performed to the motor.
Old Jul 27, 2006 | 01:49 PM
C Rock999's Avatar
as far as i know it's just a mazda reman w/ a race port
Old Jul 27, 2006 | 02:13 PM
Latin270's Avatar
10k rpms
Old Jul 27, 2006 | 02:21 PM
RacerXtreme7's Avatar
NASA geek
******"10k rpms"******
^^^Bad BLIND answer^^^
Like what drago86 said, it depends on the internals of the engine. To run higher then 8500 RPM safely and RELIABLY you need extra clearances (EX: rotor width needs clearancing, rotor and main bearings need extra clearance, eccentric shaft needs tapering), hardened stationaries, locked rotor gears, higher pressure oil (110 psi), windowed bearings, and suitable apex seals. Without knowing whats in it I'd stick to a 8500 RPM redline. Besides, its a freakin P Port TURBO, you should be making able power assuming your turbo is spec'ed correctly. Have any specs on the turbo?
~Mike.............
Old Jul 27, 2006 | 02:35 PM
Latin270's Avatar
~Mike.............
Not blind brother! I have many friends who's cars are running PP turbo or NOS. Seen them go 11k with that set up ^^^. Now weather or not this perticular engine can do it is a diffrent story but if one would turbo a PP 13b, one would only guess that all the internals are set up for such an application. So if logic serves me correctly ...... my answer stands! 10k
Old Jul 27, 2006 | 02:53 PM
C Rock999's Avatar
it's a greddy t78 from rx7store.net
Old Jul 27, 2006 | 03:08 PM
drago86's Avatar
If its stock internals dont go over 8500 S5 or 8000 s4.
Stock internals are not suitable for the power curve of a PP motor, the power peak will most likely be at 8.5-9k.
Old Jul 28, 2006 | 09:22 PM
Lightbulb
There's a big difference between a PP (peripheral port) and a race port. Sounds like the motor might just have an aggressive streetport. stock 8k redline for you!
Old Jul 29, 2006 | 07:47 PM
Latin270's Avatar
so it's not a pp 13b??? errrrrrr
Old Aug 5, 2006 | 02:02 AM
BigJim's Avatar
trainwreck
yea i thought the apex seals start to chatter at about 8200.
Old Aug 5, 2006 | 07:24 AM
I dont' think it's quite that low. I've seen 8400ish rpms with no problems, but I wasn't making power there so no need to rev it that high.
Old Aug 6, 2006 | 05:02 AM
eriksseven's Avatar
Make Money.
Umm... PP/T-78? Sounds like an unusually insane setup to be asking these questions... If I were you, I'd chill out and talk to the builder or previous owner to find out their recommendations. If what you're saying is true (and that thing has the correct mods), then you potentially have a crazy fast Rx7 and you need to be careful with that thing.
rgordon1979
40
Mar 15, 2022 12:04 PM
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
