Chssis swap, need opinions and suggestions!
Old Jul 19, 2006 | 11:06 PM
staticguitar313's Avatar
R.I.P. Icemark
Exclamation Chssis swap, need opinions and suggestions!
I recently decided that my '91 chassis isnt worth building up, but all the parts on it are worth keeping. I can get my ex' gf's poorly running 88gxl for $500 with a straight rust free body, i want to swap just about everything into the S4.5 chassis from the '91, heres my issues questions and what not.
Both cars have 5 lug with vented rear rotors
Both cars have power windows,doorlocks and security
Both have rear wipers sunroofs etc.
BOTH NA!
Which wiring harnesses should i use?
the turnsignals and hazards (along with a few other electrical components on the 88 have gone AWOL.
i'm using a fresh built S5 engine and probably the trans too, arent the s4 and s5 tranny mounts different?
which body harness should i use?
stick with manual belts?
stick with s4 gauge cluster?
s4 or s5 ac system?
use doors from s5?
lots to consider
planning on stripping the 88 to a rolling chassis and re-painting it black (like the 91) then building it up
emissions issues form using a '91 engine and emissions system in an 88?
lots to think about . . . any tips would be great
Old Jul 20, 2006 | 02:52 PM
R.I.P. Icemark
yes no?
Old Jul 20, 2006 | 09:23 PM
McTinkerson's Avatar
Leave it Stock?!
Welcome to my world. Personally I would say go for it but you'll need patience and time. It's been one month since i started my teardown/swap/rebuild/resurection and i just finnished the disassembly. A good body is a wonderful thing to have on a seven and down the road it will pay off but then again thats just my $0.02
Old Jul 21, 2006 | 01:43 AM
R.I.P. Icemark
Yeah, i think i'm keeping the S4 body harness, but i'm definetly using the S5 engine harness and ECU, i think im sticking with manual belts and s4 guage cluster, since s5 has been known to be much more inaccurate.
Old Jul 21, 2006 | 02:26 AM
Omixeo's Avatar
'89 GTUs
Im glad Im just swapping an engine/tranny and misc interior parts. You sir have your work cut out for you.
Old Jul 21, 2006 | 09:39 AM
J-Rat's Avatar
Alcohol Fueled!
BOTH NA!
s4 or s5 ac system?
use doors from s5?
lots to consider
S4 and S5 engine mounts are the same. The electrical is going to be some source of problem for you.
Old Aug 13, 2006 | 11:10 PM
R.I.P. Icemark
Still need some answers on this
i'm going to huse the s5 engine, transmission, harness and ECU will the s5 ecu be compatible with the body harness on the s4.
Still dont know if s4 and s5 n/a transmission mounts are the same or not . . .
Old Aug 14, 2006 | 07:05 AM
My5ABaby's Avatar
Rotaries confuse me
S4 and S5 crossmembers are different. Just get the appropriate one and you'll be good.
Read this:
http://www.rotaryresurrection.com/2n...o_s4_swap.html
Old Aug 14, 2006 | 02:24 PM
R.I.P. Icemark
already did, and you didnt read my post very well, I DONT WANT TO USE THE S4 HARNESS ECU OR ANYTHING ON THE ENGINE REALLY! I WANT TO USE THE S5 ENGINE HARNESS ECU TRANS ETC.!I WANT TO DROP THE LONGBLOCK IN PERIOD
Old Aug 14, 2006 | 02:34 PM
J-Rat's Avatar
Alcohol Fueled!
So whats stopping you?
Old Aug 14, 2006 | 02:36 PM
R.I.P. Icemark
not much just would like info on relations between the body harness and engine harness
Old Aug 14, 2006 | 03:00 PM
robtechfabrications's Avatar
needs an FD
why keeping the s4 cluster? s5 has a higher redline...wouldnt the tach on an s4 not be up to par?
Old Aug 14, 2006 | 03:05 PM
J-Rat's Avatar
Alcohol Fueled!
So you basically want to strip your 88 down and make it an S5 car, correct?
Old Aug 15, 2006 | 07:26 AM
My5ABaby's Avatar
Rotaries confuse me
Read the link I posted.
mulcryant
Sep 9, 2015 05:24 PM
whinin
Sep 5, 2015 11:52 PM
