--Electrical to Mechanical O.M.P.?--
Old Feb 25, 2002 | 01:21 AM
Poweraxel's Avatar
Originally posted by gmonsen
you have to drill an additional hole just off the side of the edge on the housing where the omp went and you add a mounting plate to even the surfaces. then its just bolt it in and add the line and you're done. is a couple of hours work. no more premixing. -gordon
also you'll need to fab a throttle actuated "arm" to pull on the OMP's throttle actuated valve..or you could just wire the OMP wide open...either way
Old Feb 25, 2002 | 01:31 PM
Bacon's Avatar
IRS 4 Life
the mechanical had a throtle actuator arm the elec dosent
Old Feb 26, 2002 | 08:49 PM
allrotor93's Avatar
OMP
I think the OMP is bad on a 1994 I just bought. We tested all of the lines in the harness and in the ecu, checked all of the connections for the OMP and the check engine light for the OMP still comes on. As soon as the car starts to build any boost, the car boggs down as if it were in limp mode. Any of you ever had this problem? Any suggestions would be great. I also just ordered a haltech for my car. What do I need to do to the OMP to use the haltech? Thanks.
SRTx781
Dec 19, 2015 07:30 PM
Jmpabon93
Sep 30, 2015 04:57 PM
