ECU failure?
Old Feb 19, 2002 | 08:22 PM
Struggly's Avatar
ECU failure?
Hey,
Has anyone ever had their ECU develop problems? If so, what are the symptoms of an ECU problem? Is it possible that a flaw in the ECU can mess up one system while leaving the rest of the car fine.
Only reason I ask is that I have a persistent idle problem that is defying diagnosis: Not the AWS, not a intake tract leak, not the MAP sensor, not the TPS. The only things I haven't checked are the one-way valves in the vacuum line system and the idle speed control solenoid (the resistance on this solenoid is fine, but I have yet to remove it and test for sure if it works).
Clint Fralick
Struggly@hotmail.com
Old Feb 20, 2002 | 04:31 AM
evel333's Avatar
Any mods? What is the condition of your engine?
Old Feb 20, 2002 | 08:05 AM
cewrx7r1's Avatar
Eye In The Sky
That's easy to test, swap ecus with a friend.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Erosangel
Sep 18, 2015 04:06 PM
