Jesus I Hate This Car!!!
Old Feb 19, 2002 | 05:52 PM
Liquid Anarchy's Avatar
We come with the Hardcore
Angry Jesus I Hate This Car!!!
My GTU started out slighty smoking when I loaded it on the trailor to take it home. Then it died. Wouldn't start again. So I did the ATF trick, swapped out the spark plugs, and walla! Running RX-7... but it smoked like a BITCH! Ran it a bit, smoke settled down, still smoked at high RPM. Changed the oil ( Castrol GTX 10-W30 ) and proceeded to drive it hearing "It'll smoke for as much as 3 weeks after the ATF trick". Well... it's been 3 days, it still smoked. Take it out of the driveway and *BUZZZ* oil level warning light. I stop the car, pop the hood, pull the dipstick, no oil on the dipstick. I say ****, put it back in the garage, and come to the forum...
Oil gague stayed at ½, engine sounds good, smoking from exhaust manifold.... EVIL EVIL GTU!!
What is the problem?
Did the ATF eat the oil seals? Did the oil leak somewhere ( no oil leaks on the ground )? Did aliens steal all the oil? WHAT'S WRONG!!!
Old Feb 19, 2002 | 05:57 PM
cymfc3s's Avatar
I Raise Chickens
dude, you guys are doing the "atf trick" for NO good reason. Car runs like ****, dump tranny fluid in it. Christ, thats not how you fix a car. If you fill the motor with tranny fluid you going to make some weak oil control rings even worse. Fix one problem at a time and go from there.
Old Feb 19, 2002 | 06:07 PM
neofreak's Avatar
accept no imitations™
but its a miraculous cure all for whatever problem you have. =)
Old Feb 19, 2002 | 06:12 PM
This car did NOT run when I bought it, the carbon buildup was so bad. After doing the ATF trick it ran pretty well. I don't just run out and do things for the fun of it. In fact if you look I posted to the forum the problem with this car and they recommended the ATF trick. It did fix the car so I see no reason for you to say "this is no way to fix a car." There are a number of very good mechanics on this forum that suggested that.
I doubt that so many could be wrong!
If you cannot suggest a solution then please keep your snide comments to yourself.
If anyone out there that has a comment that is helpful and might tell me what direction to go next please post it!
Thanks
Old Feb 19, 2002 | 06:14 PM
Yet another stupid, and usless comment from the peanut gallery....
Old Feb 19, 2002 | 06:19 PM
cymfc3s's Avatar
I Raise Chickens
You said it yourself, it started then died. If you got it to start, its NOT carbon locked, it was flooded. To unflood a rotary, you dont need to pour tranny fluid in it. And if I dont have all the info, i cant really suggest a course of action. And im not going to do search the forums for a history of your car. =P Regardless of the oil consumption and smoking, does it run ok?
Old Feb 19, 2002 | 06:21 PM
cymfc3s's Avatar
I Raise Chickens
relax man, this is the 2nd gen section, not the 3rd gen section.
Old Feb 19, 2002 | 06:33 PM
Poindexter10thae's Avatar
AKA Poindexter
It sounds like rebuild time, from the symptoms you describe it sounds like one of the oil control O-rings on the rotor housings is gone. Check your coolant, does it smell like exhaust? Do you run out of coolant?
Old Feb 19, 2002 | 06:55 PM
10TH_ANNIV_T2's Avatar
What color was the smoke, really white I believe is coolant, more of a bluish/darker color generally is oil. While I'm slightly sympathetic to some of the comments, giving a few more specifics would help. Not trying to start anything, just trying to help, mmmKay? Here's Mr.Smiley face: Nobody can be mad an Mr. Smiley face.
I would agree, if the motor hasn't been sitting for a long time, and turns over, it's probably not carbon lock.
Old Feb 19, 2002 | 07:20 PM
So true so true.
The last 2 comments were made by my mother on my behalf
The smoke in question is a SOLID white/grey. It LOOKS like ATF smoke ( as per pictures of people doing the ATF trick ). It had been smoking after 2 days of hard driving, and when I went to start it today, it blew some more smoke, like it had since the ATF, and the oil light came on.
I changed the oil and filter this past weekend, along with the spark plugs. The coolant is STILL the coolant that was in it when it sat, but I haven't smelled it.
The Events of the past week and a half:
When we moved the car to load it on the trailor upon buying it (where it had been sitting for approx. 6 months), it smoked. When it died, it threw a good 2 foot flame at my legs. When we got it home, I did the unflooding procedure ( EGI fuse ) and that didn't work, so I followed up with the ATF unflood. That worked, but it only ran for approx. 2 minutes and then died. So I think "compression"! And did the ATF trick, because I was under the impression It can't hurt anything but the spark plugs, and the O2 sensor.
After the ATF trick, and a little re-timing ( Timing was advanced by quite a bit ) the car ran, however it hopped at low RPM. After another post and some research, I dumped a bottle of Injector Cleaner in it, and it's been driving better day by day. Then today, when I pulled it out and warmed it up, *BUZZZ*
I hadn't checked the oil since the day after I changed the oil. Haven't checked the coolant other than to say "Yea, it's got coolant"
I'll go check that now... I'll be back in a few moments.
Old Feb 19, 2002 | 07:24 PM
Coolant is fine. Smells like anti-freeze. To the top. Green. Kindof sugary. Don't know what else to say about it...
Old Feb 19, 2002 | 08:11 PM
But the ATF smoke should go away relatively quickly, no? I mean, it shouldn't still be smoking after an hour of running.
I'd have to guess you're burning way too much oil, probably say a compression test may be a bit low, but maybe some other internal oil leak. New engine may not be so unreasonable of a guess.
Either way, hopefully you have a good set of tools....
Greg O.
Old Feb 19, 2002 | 09:09 PM
Huge set of tools. Fully functional shop. And if there's a tool I don't have. I have spare steel, a cutting torch, and a welder.
With all that, anything's possible
Old Feb 19, 2002 | 09:15 PM
now coming up with the at LEAST $400 for a rebuild... that's another story.
Old Feb 19, 2002 | 10:15 PM
Felix Wankel's Avatar
Super Newbie
Quick oil control o ring test:
Take it up to redline in 2nd or 3rd gear, let off the gas (still in gear), then punch it back to the floor after it loses a couple thousand RPM. If the oring is shot, it will spit out a bunch of smoke when you punch the gas the second time...
Old Feb 19, 2002 | 10:44 PM
niner's Avatar
have you checked compression?
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
