Sponsored by: CARiD
is this housing bad?
Old Jun 16, 2006 | 05:44 PM
SF@Rx7's Avatar
just pulled the rear housing for a swap
it is my gsl-se engine with about 100,000 miles on it
just got some pic of it
does the housing looks bad to any of you?
Attached Thumbnails is this housing bad?-cimg0251_resize.jpg   is this housing bad?-cimg0254_resize.jpg   is this housing bad?-cimg0252_resize.jpg   is this housing bad?-cimg0250_resize.jpg
Old Jun 16, 2006 | 07:10 PM
Rocking Rotary's Avatar
It doesn't look to be in the best of shape.
What does that gouge by the exhaust port reall like? If you finger nail catches on it its junk. If its smooth you may be able to reuse but its not going to build outstanding compression. Looks like you had some apex seal chatter as well. It does have 100k on it, these thing dont last for ever.
Old Jun 16, 2006 | 08:40 PM
nukeall's Avatar
Look at them Water jackets they rusty!!!
Old Jun 16, 2006 | 10:14 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
you can reuse those if you're poor--just sand down any ridges on the gouges until they're flush.
of course if you have the dinero, hit up some new ones.
Old Jun 16, 2006 | 11:53 PM
j9fd3s's Avatar
Community Builder
yep, it should be replaced, but if you didnt it would run
Old Jun 18, 2006 | 05:41 PM
t-von's Avatar
Rotor Head Extreme
As long as the damage isn't on the compression side of the housing, you will be fine. As mentioned earlier, sand them down to remove any nicks.
Old Jun 29, 2006 | 04:50 PM
Midwest 7's's Avatar
sellout
i definitly would not use that housing. did the motor blow a seal?
cristoDathird
28
May 30, 2019 08:47 PM
rotor_veux
Sep 3, 2015 07:10 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
JZW
20B Forum
Aug 18, 2015 08:56 PM
