Other GM Small Blocks
Old Jun 13, 2006 | 06:59 PM
rgby12's Avatar
Question Other GM Small Blocks
I have a fresh 383 Stroker that I was having built for a '69 Camaro that I was going to buy but the deal never went through. Will it be just as easy to put that motor with twin Holley 700 carbs in my '88 Vert as it would be a LS1?
Any information would help. Thanks
Old Jun 13, 2006 | 07:22 PM
peejay's Avatar
Old [Sch|F]ool
Damn, thought this was goign to be info on *interesting* engines like Olds or Pontiac or Buick or, yes, even the Caddy engines, but nah, it's all Chebby juuunk.
Old Jun 14, 2006 | 04:31 PM
Crash Test Joey's Avatar
Zero Rotor Motorsports
It will fit in there just as easily, but it won't clear the hood where an LS1 would. If you don't mind a hole or a scoop, go for it.
Why not use a VW motor? That would be "interesting" as well but isn't going to produce the same results, either.
Old Jun 14, 2006 | 11:34 PM
Orr89rocz's Avatar
yeah it will fit... dimension wise, the motors are close. just need the parts to swap it in.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
13
Jan 9, 2018 11:19 AM
dillrx7
Sep 7, 2015 09:38 AM
