Sponsored by: CARiD
Car loses power halfway on throttle.
Old Jun 11, 2006 | 01:22 PM
richardm's Avatar
I have a 1990 turbo fc, and IM having a very strange problem that not even the rotary shop by can figure out. Basically when I push the throttle down about halfway the engine starts to cut out and putter, then if I lift my foot up bellow halfway the car gains its power back. So I cant accelerate past half throttle without the car losing its power and puttering.
The rotary shop by me who looked at it for about a week said they thought it was a bad air intake sensor and replaced and it still had no effect, so they suggested it may be the wire harness. Oh also when I ever I step on my brake or turn my lights on my radio cuts out and the lights in the car dim for a second. These problems kind of happend close to each other.
Can anyone help me out?
Thank you
Old Jun 11, 2006 | 02:20 PM
BuckyFD3's Avatar
GT4088R
Sounds like dodgy earths to me.
Old Jun 11, 2006 | 03:10 PM
RETed's Avatar
First of all, who the F*CK is this idiot "rotary shop" guessing it's the air temp sensor???
Please tell us so the rest of us AVOID this place!
Second, are you running the stock ECU?
Do an error code scan - it should tell you what is wrong with your car.
There's a good chance you'd get an OMP error.
Else, your TPS is bad...
-Ted
Old Jun 11, 2006 | 03:24 PM
spot_skater's Avatar
The Cause of Death
Check your MAF sensor. When mine went bad I had similar issues.
And tell the "shop" your brought your car to to take your money and shove it up their ***.
Old Jun 11, 2006 | 04:24 PM
NeedFD's Avatar
R. R. R.
how many miles on the o2? that can also cause fuel dumping problems.
Old Jun 14, 2006 | 09:47 PM
BASTARD's Avatar
you may have a fuel delivery problem... clogged filter, bad injector or fuel pump on the way out
Old Jun 17, 2006 | 12:10 AM
twin fd3s's Avatar
i have a fd with the same freekin prob if i figure it out i will let you know good luck maybe you can fix yours before i can
Old Jun 24, 2006 | 02:22 PM
dsmrx7's Avatar
Same thing I was thinking...
ChrisRX8PR
Aug 21, 2015 01:56 PM
gtcd
30
Aug 19, 2015 02:44 AM
cam_7779
Aug 18, 2015 07:48 AM
sYnth.
Aug 17, 2015 07:28 PM
