How big Intercooler?
Old Feb 17, 2002 | 06:44 PM
gzon's Avatar
What size of an Front mount intercooler can i get into my 92 FD?
What size do you got and how much power do you take out of your engine?
Or does a OEM fitted ones work just as good?
Old Feb 17, 2002 | 06:48 PM
RyanREX's Avatar
Killer Turbo Twins
Re: How big Intercooler?
Originally posted by gzon
92 FD?
Old Feb 17, 2002 | 06:57 PM
rx7even's Avatar
Re: Re: How big Intercooler?
Originally posted by RyanREX
You do know they had 91 and 92 FD's dont you? He's not from the US, they have those over there.
Old Feb 18, 2002 | 08:39 AM
gzon's Avatar
Talking
Yepp my FD is 92.... probobly much the same as an 93 over there.
Anyone willing to answer my question? It doesnt have to be a 92 that you got.
Or does everyone of you still got the crappy OEM IC???
Old Feb 18, 2002 | 09:17 AM
Malachi151's Avatar
from Children of the Corn
Mine is a 92 also. Its called a 93, but it was made in July 92.
Anyway, just check the RX-7 store, the link is above. Any of those ICs will work fine.
Some people use stock mount and some use front mount.
It really doesn't matter that much, because the ICs are 100 times better then stock, so just as long as you upgrade, your fine.
Old Feb 18, 2002 | 09:48 AM
RyanREX's Avatar
Killer Turbo Twins
Re: Re: Re: How big Intercooler?
Sorry about that...
Old Feb 18, 2002 | 10:50 AM
OC94Rx7's Avatar
_________________________
Martin - the closest place to you, That I know of is: www.k-power.dk
They have front mounted HKS intercoolers. PM me, I know someone who is uses this unit in Denmark. If, your not interested in HKS. I will try to help you out.
Old Feb 18, 2002 | 11:32 AM
gzon's Avatar
I was thinking maybe get a local make an IC for me. 100$ for the job plus core.
Ive found a core thats 690*240*110 millimeters.
Will i get that into my front?
Old Feb 18, 2002 | 11:36 AM
95R2-89TII Ground Zero's Avatar
Banned
Sounds like it should work...I had to do the conversion because of the whole American measurements thing.
Old Feb 18, 2002 | 04:55 PM
gzon's Avatar
In your sizes it should be 27.17 * 9.5 * 4.3 Inch
How about the depth? Can I lift the Water and AC coolers to get more space?
Old Feb 18, 2002 | 04:59 PM
the_glass_man's Avatar
Will u do me a kindness?
Damn thats big!!! Where can I get one? I think that is a little thick, anything over 3.5" is kind of a waste. You may have some major fitment issues, not to mention if you didn't you may have to trim a lot of the inside of your bumber, good luck!
Old Feb 18, 2002 | 05:13 PM
gzon's Avatar
No I dont want to cut my bumper. But If I could get the other coolers a little back it may work.....
Thats the "small" one I´ve found. It would cost 300$ for the core plus 100$ for the "sides". so its pretty cheap.
Old Feb 18, 2002 | 06:21 PM
7-sins's Avatar
thats not paint....
Is this big enough... its the Greddy IC.
Old Feb 19, 2002 | 02:36 AM
gzon's Avatar
How big is it?
Ive seen some cars that I think have got their other coolers a little bit back. Anyone done that here?
Old Feb 19, 2002 | 04:21 AM
lesd's Avatar
I made this one when I had a single turbo rotary engine in there. It was a horizontal mount, and the core was 4 1/2 in. thick. The volume of the core was 780 cu in.
Old Feb 19, 2002 | 09:43 AM
gzon's Avatar
odd placement. Did you got vents in the hood?
Old Feb 19, 2002 | 10:36 AM
Hyperite's Avatar
Vagina Junction
And what's with the position of the air filter above the passenger headlight? Doesn't even look like you could use the lights! Maybe he just doesn't have a hood.
~Tom
Old Feb 19, 2002 | 10:44 AM
Mld>7's Avatar
I Post Mad Quick Yo!
yah ive seen that type of placment a few times...
i think thats the front mount radiator setup for racing apps.
front mount FC is more for darg i think...
or is it visa versa, correct me if im wrong!
ls1swap
Jun 3, 2024 03:25 PM
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
