My Fd Setup: Any Recommendations???
Old Jun 5, 2006 | 05:57 PM
JUGGAKNOTZZ's Avatar
Foxhunting....
I HAVE A NEW-STOCK PORT 13B ENGINE, WITH 3MM APEX SEALS THAT I WILL BE DROPPING INTO MY FD HERE IN THE NEXT COUPLE OF WEEKS. I HAVE BEEN ACCUMULATING PARTS FOR THIS OVERHAUL FOR QUITE SOME TIME NOW... HERE IS LIST OF MY MODS SO FAR;
POWER FC +COMMANDER
HKS TWIN POWER IGNITION
RE TOE LINKS/TRAILING ARMS
APEX'i AVC-R BOOST CONTROLLER
EFINI Y-PIPE
3" HI-FLOW CAT
RE AMEMIYA SHORT SHIFTER
APEX'i TURBO TIMER
HKS SSQ BOV
GREDDY OIL CATCH TANK (9MM)
RE 25 ROW DUAL OIL COOLERS
SAMCO COOLANT HOSE KIT
SAMCO TURBO HOSE KIT
FLUIDYNE RADIATOR
STAINLESS OIL LINES
HOSE TECHNIQUES VACUUM HOSE KIT
PETTIT AST
TO BE ADDED SOON:
KAAZ LSD
J & S KNOCK SENSOR
HKS RS INTAKE
APEX'i GT SPEC (3.74in.)
PETTIT 3" SS DP
SARD FUEL PRESS. REG
NGK PLUGS
HKS HYPER GROUND
FC THERMOSWITCH
TECHEDGE WIDEBAND
TEIN FLEX
DO I NECESSARILY NEED A GREDDY PULLEY KIT?
MY GOAL IS TO MAKE 410-460 HP WITH THESE MODS, MEDIUM SIZED SINGLE TURBO APPLICATION , HKS V-MOUNT, AND UPGRADED FUEL RAIL, INJECTORS, PUMP (SUPRA TT)......
FEEL FREE TO PROVIDE CREDIBLE GUIDANCE OR TO SUGGEST ANYTHING THAT I MAY HAVE FORGOTTEN AS FAR AS RELIABILITY MODS???.......THANKS!!....BEN
Old Jun 5, 2006 | 05:58 PM
Foxhunting....
P.s. .......this Will Be A Moderately Driven Vehicle............buuuump
Old Jun 5, 2006 | 06:00 PM
Foxhunting....
Also, Exedy Stage 4 Twin Clutch And Flywheel Will Go On When Single Turbo Goes On.....haha.....buuump!
Old Jun 5, 2006 | 06:16 PM
A3ON7's Avatar
well i prefer ACT twin clutch and that's what i'm going to buy. What's the differnets between this 2 clutch anyway?
Old Jun 5, 2006 | 06:21 PM
VegasFD's Avatar
Wishin I Still Had The FD
While your first group of mods are a pretty good base to start with, I would definately put the downpipe higher on your priority list. The stock pre-cat is a piece of shiet.
Old Jun 5, 2006 | 06:23 PM
VegasFD's Avatar
Also, you should already be running NGK 9's in leading and trailing. And a lot of people agree that the HKS hyper ground is a waste of money.
Old Jun 6, 2006 | 12:34 AM
Foxhunting....
ACT clutches are VERY nice, but i like Exedy Sports clutch kits with twin and triple carbon plates...DP is one of the next things I do. PETTIT makes a very nice, easy fitting SS pipe that I am gonna go with (3").....
WWW.ADVANCEDCLUTCH.COM
WWW.EXEDYUSA.COM
http://www.advancedclutch.com/produc...0236mm&go=true
[B]Any other insight? ......Quick spooling, ball bearing, Single turbo app for about 450 solid rwhp @ about 17-18 psi? Any Recommendations...???
Old Jun 6, 2006 | 12:42 AM
FDNewbie's Avatar
Sponsor
Yo what up big man Here are my comments:
- Ditch the Apexi AVC-R Boost Controller. Too complicated. Get a simple Greddy Profec B (old school one) or the new Profec Type S.
- Ditch the Apexi Turbo Timer. No need for a turbo timer. If you know how to coast into your neighborhood w/o boosting, those 30 sec. before getting to your crib are more than 'nuff to allow the turbos (which are water AND oil cooled) to cool down.
- Don't know much about the J & S Knock Sensor. Is it really necessary?
- Hit up Chuck re: the grounding system he found to be the most effective. I forget which one it was, but it wasn't the HKS unit.
- Greddy pulley's a good idea if you don't have a large sound system. Hit me up if you need one. I have one laying around (and I'm back at home)
- For the clutch, the best on the market by far for power AND drivability is the Exedy D-Core Twin Plate. As usual, hit me up and I'll get ya a sweet deal on one In fact, I'mma be rockin one myself soon
~Ramy
Old Jun 6, 2006 | 01:10 AM
rynberg's Avatar
1. If you are going single turbo, the Pettit downpipe won't work. You either buy a single turbo kit or have a custom downpipe made.
2. The J&S knock sensor is a POS IMO....I can't recall actually seeing anyone benefit from it, while many have had problems (in past years). I didn't even know they were still selling that thing. Water injection would be 10x better.
3. I don't know why you would run a hi-flow cat with a single turbo....you won't be making 400+ rwhp with it, that's for sure.
4. I don't see a fuel system upgrade listed.
5. You don't need the FC thermoswitch if you are running the Power FC.
6. I don't see the FC-Datalogit on your list.
7. I don't see an intercooler on your list! This is very important and will determine what intake system you can run, whether you need the Efini y-pipe, whether you need the Greddy elbow, etc.
8. WHY DO PEOPLE KEEP BUYING TURBO TIMERS???
Old Jun 6, 2006 | 01:23 AM
FDNewbie's Avatar
Sponsor
Rynberg, he mentioned a V-mount and fuel system in the last line of his first post. But I totally missed the hi-flow cat. Ditch that crap man. You NEED a midpipe.
Oh and just to clarify, you do need a FC thermoswitch if you don't have a datalogit. Or visa versa
Old Jun 6, 2006 | 12:49 PM
Foxhunting....
THATS THE TYPE OF FEEDBACK IM LOOKIN FOR RIGHT THERE!! THANKS A LOT RYNBERG AND OF COURSE, RAMY (FDNEWBIE)...I AM GRATEFUL TO BE PART OF THIS FORUM AND AMONGST SUCH A WEALTH OF INFORMATION.....THAT EXEDY D-PLATE CLUTCH IS THE ONE I WAS LOOKIN AT TOO....http://www.exedyusa.com/products/wha...N%20D-CORE.pdf
I WILL GET A MIDPIPE AND CUSTOM DP WHEN THE SINGLE TURBO GOES ON, ....
DATALOGIT ADDED TO LIST...
ANY FURTHER INSIGHT????.......
Quick spooling, ball bearing, Single turbo app for about 450 solid rwhp @ about 16-17 psi? Any Recommendations...???
Old Jun 6, 2006 | 03:06 PM
BlueRex's Avatar
Noise, smell... but if power is his main goal then you're right, he shouldn't be running a hi-flow catalytic converter.
Old Jun 6, 2006 | 03:28 PM
seanbrowning's Avatar
Well I would think since he keeps asking for 450whp his main goal is power, thus midpipe.
Old Jun 6, 2006 | 05:23 PM
FDNewbie's Avatar
Sponsor
Turbos...the options are endless. Steve Kan makes some wicked turbo kits (http://www.gothamracing.com/catalog/...43_107_116_197, in the middle, where it says GothamRacing Turbo kits etc). A-Spec's 500R is making a lot of noise. And you always have Ray @ PFS locally...
Old Jun 6, 2006 | 05:36 PM
Foxhunting....
POWER/STREETABILITY, AS THIS CAR WILL BE MODERATELY DRIVEN.....PETTIT RESONATED MIDPIPE IT IS!.....http://www.pettitracing.com/rx7/inde....htm.....THANK YOU FOR THE FEEDBACK REGARDING THE SINGLE TURBO SETUP RAMY..... ANYONE RUNNING A QUICK SPOOLING,BALL BEARING TURBO MAKING 425-450 RWHP AT 15-17 psi ?....THANKS...BEN
Old Jun 6, 2006 | 05:42 PM
FDNewbie's Avatar
Sponsor
PM Scrub (my friend Dan). He's pushing Steve Kan's turbo kit, and I'm pretty sure he dynoed at around 450.
~Ramy
EDIT: Just found the thread: https://www.rx7club.com/single-turbo-rx-7s-23/gotham-racing-gr67-dyno-numbers-491328/. 421 WHP at 15.5lbs
Old Jun 6, 2006 | 05:59 PM
cozmo kraemer's Avatar
Darkside FD
I have an A-Spec GT35R Single kit. I have a high flow cat and a gotham midpipe. I will do a side by side comparison on a dyno when I get up there. We can see for sure how much power that cat saps from the system...
My wideband will even tell how much more rich/lean the car runs on the same tune with the cat and without. I think it will be interesting.
For 450whp...A-spec's 500r kit seems to be the ticket. I was just hoping for 400whp with the 35/40r with 1.06 hot side. We will see what happens on the dyno in a couple weeks.
Old Jun 6, 2006 | 06:20 PM
Foxhunting....
Hell Yeah!....let Us Know Kraemer!...thanks So Much For Your Feedback.....
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
eplusz
15
Oct 7, 2015 04:04 PM
