Front housing Spark Plugs white (running lean) But Why ???
Old Feb 17, 2002 | 04:19 PM
badass7's Avatar
Pimpin Rotors...and Hoes
Question Front housing Spark Plugs white (running lean) But Why ???
I removed my plugs to inspect them as I did an oil change today and noticed that the two on the front have a whitish color. What could be the cause of this. I just inspected them about 4 months ago and everything looked fine...nice brownish color. What part of the Fuel system could be causing this...Fuel Filter, Fuel Pump, or Injectors?? I have been running 11-12 psi. max with a mild Street Port, Intake, DP, CB, NGK 9's Platinum and G-Force Unlimited ECU which is set up for my mods. plus an additional MP and IC which I don't have yet. I have been running this setup for nearly a year and my plugs have never showed any sign of running Lean until now. My car is a '93 Touring with a rebuilt w/17k miles and 103k miles on the Odo. Fuel filter changed when engine installed. Any info. on this is Appreciated
Old Feb 17, 2002 | 11:21 PM
badass7's Avatar
Old Feb 17, 2002 | 11:31 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
Maybe you have an injector that is clogged slightly.
Old Feb 17, 2002 | 11:36 PM
badass7's Avatar
Aside from getting New injectors....Any fuel injector cleaner that might work?? If I even have 1 bad injector, it's time for 4 Brand new ones and at least 5 Bills.
Old Feb 17, 2002 | 11:42 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
You could just send yours to RC and have them cleaned and blueprinted instead of buying all new.
Old Feb 17, 2002 | 11:44 PM
badass7's Avatar
How much does that usually run??
Old Feb 17, 2002 | 11:49 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
here is there page http://www.rceng.com/service.htm#INJECTOR
Its $24.00 per injector
Old Feb 18, 2002 | 08:27 AM
Tim Benton's Avatar
FD title holder since 94
the redline injector cleaner - S1 or whatever its called, is supposedly some good stuff. Brain at M2 uses it in the race car and street car to keep the injectors clean. Do you premix any?
Tim Benton
Old Feb 18, 2002 | 12:16 PM
badass7's Avatar
Tim Benton
Yes, I've been using Marvel Mystery Oil for about 8 months now.
rotor_veux
46
Jun 12, 2018 10:39 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
smikels
Aug 18, 2015 01:26 PM
