Egr?
Old Jun 5, 2006 | 01:28 PM
router86's Avatar
Question Egr?
do i really need my EGR valve???? that maybe whats my probelm..
Old Jun 5, 2006 | 01:33 PM
Narfle's Avatar
Rx7 Wagon
no its emissions equipment. use the search button.
Old Jun 5, 2006 | 01:38 PM
router86's Avatar
oh ok thanks could that cause boost problems
Old Jun 5, 2006 | 02:18 PM
Narfle's Avatar
Rx7 Wagon
doubtful that it would. chech valves, vaccuum lines, bad turbo control solenoid could cause boost issues. What are your symptoms?
Old Jun 5, 2006 | 02:38 PM
router86's Avatar
im reading a good vac on my gage... but when i accelerate it never boost... if feels like somthin is holding it back. if i am on the accelerator for a while it feels like somthing finally gives and lets it boost... but it never gets over 5 psi... you can hear the turbos charging but its like the boost is going somewheres else... i have checked the acuators and vac. lines and everything seems ok.
Old Jun 5, 2006 | 07:05 PM
Fubawu's Avatar
The vac check valve is clogged or broken. Easy and cheap to fix
John
Old Jun 5, 2006 | 07:13 PM
router86's Avatar
where is that located... near the intake? or underneath?
Old Jun 6, 2006 | 08:29 AM
Fubawu's Avatar
It is underneath the "vac box" not sure of it's true name. up by the manifold. You have to take the Hose off that conects your ic to your turbo to see it.
John
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Skeese
65
Mar 28, 2017 03:30 PM
Prediict
32
Nov 18, 2015 08:41 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
