How hard must you torque the spark plugs?
I don't have a torque specification, but since it is a gasket style plug half a turn after gasket contact. From the NGK spark plug package.
Really, really tight is good since you don't want them to leak or vibrate loose and fall out, but be carefull - not too much or your pistons will slam into them and break. At least 200 ft. lbs should work, maybe more.
(j/k.. turn until they seat and give them a little extra turn with the wrench. You will feel them stop. They need to be "snug". A torque wrench is not needed. ALWAYS use anti-seize or you will be sorry)
Trending Topics
pfffh, 200 ft. lbs is not even close enough on the tightness. You need at least 350 ft. lbs of torque with red locktite. My buddy's niece's daughter had a FD torqued its spark plug to 200 ft. lbs and the thing shot out like a overboosted piston after 5 miles and shattered on driver side strut followed by engine fire. She was burned alive from that accident while she was on her way to school.
Just put some locktite and then use a high torque impact gun (about 1600 ft. lbs) and impact it to for like 5 minute straight and you will be good. Be sure to measure the clearance with a 0.0012 feelers gauge between the plug and the housing so it dosent go too far in.
No don't do what I just said above, you will need a pair of new rotor housing plus a set of new spark plugs if you do that.
But the reason why I brought this thread back to life is because it's almost that time of the year when ppl bring dead threads back to life to spook others out. You know... Halloween
trick or treat!
Well this isn't the lounge my friend, this is the technical section.
We all have a sense of humor..... when something is actually funny
I'll let your shenanigans slide this time, but the next time you post make sure that it's actually something relevant. Thanks
Ease up, and RonKMiller's post in '02 was not in jest also?. While this was dragged out of the dungeon someone else may be incapable of reading a service manual or spark plug packaging.
If they can't read an FSM, can't read a label and can't bother to search for this or other similar threads, they shouldn't be changing plugs. Bringing this thread back was pointless.
It has more to do with DairokutenMaoh bumping an age old thread with nothing positive at all to add to it.
alphawolff
Nov 17, 2015 05:57 PM
